9/15/2011 2:46pm - Uplink Activity Report - 44 changes | SatelliteGuys.US
D
DigiDish Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 9/15/2011 2:46pm - 44 changes
Uplink Comparison Range: 09/15/2011 02:31P - 09/15/2011 02:46P
Channel Additions:
5263(11) - WTHID [MPEG4 HD] added to Ciel-2 129W TP 12 Spotbeam 30 (Mkt:Terre Haute, IN-Terre Haute, IN-N/A) (NA)
5204(5) - KRBK [MPEG4 HD] added to EchoStar8 77W TP 10 ConUS beam (Mkt:Springfield, MO-Osage Beach, MO-N/A) (NA)
7804(23) - 4FREE [MPEG2 SD] added to EchoStar11 110W TP 11 ConUS beam (Mkt:San Juan, PR) (A) (H)
8945 - MGTV [MPEG2 SD] added to Anik F3 118.7W TP 18 ConUS beam (NA)
9539(451) - HDALT [MPEG4 HD] added to Ciel-2 129W TP 25 ConUS beam (HD Alternate Channel) (NA)
9539(451) - HDALT [MPEG4 HD] added to Nimiq5 72.7W TP 08 ConUS beam (HD Alternate Channel) (NA)
9539(451) - HDALT [MPEG4 HD] added to EchoStar15 61.5W TP 30 ConUS beam (HD Alternate Channel) (NA)
9574(452) - HDALT [MPEG4 HD] added to Ciel-2 129W TP 25 ConUS beam (HD Alternate Channel) (NA)
9574(452) - HDALT [MPEG4 HD] added to Nimiq5 72.7W TP 08 ConUS beam (HD Alternate Channel) (NA)
9574(452) - HDALT [MPEG4 HD] added to EchoStar15 61.5W TP 30 ConUS beam (HD Alternate Channel) (NA)
9575(453) - HDALT [MPEG4 HD] added to Ciel-2 129W TP 25 ConUS beam (HD Alternate Channel) (NA)
9575(453) - HDALT [MPEG4 HD] added to Nimiq5 72.7W TP 08 ConUS beam (HD Alternate Channel) (NA)
9575(453) - HDALT [MPEG4 HD] added to EchoStar15 61.5W TP 30 ConUS beam (HD Alternate Channel) (NA)
9576(474) - HDALT [MPEG4 HD] added to Ciel-2 129W TP 25 ConUS beam (HD Alternate Channel) (NA)
9576(474) - HDALT [MPEG4 HD] added to Nimiq5 72.7W TP 08 ConUS beam (HD Alternate Channel) (NA)
9576(474) - HDALT [MPEG4 HD] added to EchoStar15 61.5W TP 30 ConUS beam (HD Alternate Channel) (NA)
9577(475) - HDALT [MPEG4 HD] added to Ciel-2 129W TP 25 ConUS beam (HD Alternate Channel) (NA)
9577(475) - HDALT [MPEG4 HD] added to Nimiq5 72.7W TP 08 ConUS beam (HD Alternate Channel) (NA)
9577(475) - HDALT [MPEG4 HD] added to EchoStar15 61.5W TP 30 ConUS beam (HD Alternate Channel) (NA)
9578(476) - HDALT [MPEG4 HD] added to Ciel-2 129W TP 25 ConUS beam (HD Alternate Channel) (NA)
9578(476) - HDALT [MPEG4 HD] added to Nimiq5 72.7W TP 08 ConUS beam (HD Alternate Channel) (NA)
9578(476) - HDALT [MPEG4 HD] added to EchoStar15 61.5W TP 30 ConUS beam (HD Alternate Channel) (NA)
Channel Removals:
7334 - WFLI (A) (H) [MPEG4 SD] removed from Echostar12 61.5W TP 03 Spotbeam 6 (Mkt:Chattanooga, TN-Cleveland, TN-CW)
5780 - PTATA (NA) [MPEG4 HD] removed from Anik F3 118.7W TP 32 ConUS beam (Mkt:Abilene, TX)
5781 - PTATC (NA) [MPEG4 HD] removed from Anik F3 118.7W TP 32 ConUS beam
5782 - PTATN (NA) [MPEG4 HD] removed from Anik F3 118.7W TP 32 ConUS beam
5783 - PTATF (NA) [MPEG4 HD] removed from Anik F3 118.7W TP 32 ConUS beam
19907 - BMG08 (NA) [175] removed from Anik F3 118.7W TP 07 ConUS beam
19907 - BMG08 (NA) [175] removed from EchoStar14 119W TP 19 ConUS beam
19907 - BMG08 (NA) [175] removed from Nimiq5 72.7W TP 21 ConUS beam
Channel Moves:
149 - FSC [MPEG2 SD] moved from EchoStar11 110W TP 11 ConUS beam to EchoStar11 110W TP 02 ConUS beam (Fox Soccer Channel) (A)
149 - FSC [MPEG4 SD] moved from EchoStar15 61.5W TP 12 ConUS beam to EchoStar15 61.5W TP 27 ConUS beam (Fox Soccer Channel) (A)
Channel Package Flag Changes:
5255(11) - KNIN [MPEG4 HD] - Ciel-2 129W TP 04 Spotbeam 11 changed to Available (H) (Mkt:Boise, ID-Caldwell, ID-CW)
7143(9) - KBOID [MPEG2 SD] - EchoStar10 110W TP 25 Spotbeam 41 changed to Available (H) (Mkt:Boise, ID-Boise, ID-N/A)
5154(53) - WFLI [MPEG4 HD] - Echostar12 61.5W TP 03 Spotbeam 6 changed to Available (H) (Mkt:Chattanooga, TN-Cleveland, TN-CW)
5767 - IAD10 [DATA] - EchoStar14 119W TP 14 ConUS beam changed package flags (A)
5767 - IAD10 [DATA] - Nimiq5 72.7W TP 22 ConUS beam changed package flags (A)
9467(155) - NFLRZ [MPEG4 HD] - EchoStar11 110W TP 07 ConUS beam removed from free preview (A) (NFL RedZone)
9467(155) - NFLRZ [MPEG4 HD] - Nimiq5 72.7W TP 01 ConUS beam removed from free preview (A) (NFL RedZone)
9467(155) - NFLRZ [MPEG4 HD] - EchoStar15 61.5W TP 20 ConUS beam removed from free preview (A) (NFL RedZone)
Channel Mapdown Changes:
5253 - KTRV Ciel-2 129W TP 04 Spotbeam 11 mapdown changed from 11 to 12 (Mkt:Boise, ID-Nampa, ID-FOX) (A) (H)
7138 - KTRV EchoStar10 110W TP 25 Spotbeam 41 mapdown changed from 11 to 12 (Mkt:Boise, ID-Nampa, ID-FOX) (A) (H)
7140 - KNIN EchoStar10 110W TP 25 Spotbeam 41 mapdown changed from 12 to 11 (Mkt:Boise, ID-Caldwell, ID-CW) (A) (H)
Transponder Changes:
Echostar15 61.5W TP 23 ConUS beam changed from 20000 QPSK 5/6 to 21500 8PSK 2/3
Channels in the system: 8440
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
(FP) = Free Preview
The Format and Layout of the SatelliteGuys Uplink Report is © Copyright 2011 SatelliteGuys.US and may not be republished without written permission from SatelliteGuys.US.
The SatelliteGuys Uplink Report is powered by Digiblur Technologies! - DigiDish v11.07.22
© 2011 - All Rights Reserved - SatelliteGuys Incorporated
I have seen TP 23 dropped a few numbers down. Is it because of this change?
Dish runs their SD Transponders at 20000 QPSK 5/6, they put more data through on HD using 21500 8PSK 2/3. This results in more errors needing correction and is reported by the receivers as a lower signal strength. They go from around 32mbit/sec on the TP to around 41.5 mbit/sec on HD.
ljdonato said:
Anyone from Puerto Rico knows what is happening with this channel? I try to access it in any of my receivers and I only get an error, to try and "reset my receiver" (which I already did). Is this happening only to me or is anyone else experiencing this behavior?
If you press info, you will see that it's a promotion to get the distant networks in SD free for to weeks.
It's a promotion to get the distant networks in SD free for two weeks. You need to call or subscribe over the Internet.
Thanks! It never occurred to me to press "info". I knew it was about said promotion, I just thought that, maybe, the channel was to show, alternatively, different feeds from the networks included in the promotion. That way we could make our decision by watching... Anyway, although having more alternatives is always better, I am more interested in HD. Thanks, eec.
Looks like the people in Terre Haute will get FOX in HD. WTHI must be running a Fiber Optic to E for a HD feed.
D
9/14/2011 6:16pm - Uplink Activity Report - 15 changes
D
9/21/2011 6:16pm - Uplink Activity Report - 136 changes
