87W C-Band on the Edision receiver | SatelliteGuys.US
Brct203
1,492
1,629
Connecticut
I just ran into a surprising problem when scanning 87W C-Band... I do a blind scan for ITC channels and as expected it finds the 5 usual suspects:
- FolkTV
- ICTV
- ZNS
- Parliament
- OurTV
after the blind scan completes, the receiver shows the list of recently scanned services, and I can tune into any of those, no problem
But then after I change satellite and come back to 87W C-Band, it shows only FolkTV (UTFeeds) in the list.
When I inspect 87W C-band with dreambotEDIT, I see that the other channels are showing as Type 0 (Data services). I can change them to type 1 (TV) and upload to the osmio and then it's all good.
I'm using the TNAP image. I also scanned it on the Amiko receiver, all seems normal there.
Anyone else seeing the same?
Yes there is some services that do that. What I do is use the remote while they show in the Last Scanned folder highlight the channel and press menu and add service to bouquet. Favorites TV and then they stay.
Slingbox remote code for Edison Mio 4K
New to me Edision OS MIO 4K Linux Combo Box
