83W AMC-9 | SatelliteGuys.US
83W AMC-9
olegray
SatelliteGuys Guru
131
w. arkansas
Is there anything active on 83 AMC-9? On tp 12140V/30000 I get about a 70% Q, but nothing on any other tp. I'm using a 7 1/2 foot with a Invacom QPH-031 hung on the side.
There might be a test card up
11775 H 4232
RTV/RTN is on there at 11735 H 4440 but it can be very tricky to pick up
edit tp
Try editing the tp from 11735 to 11734. It worked for me.
TP - 11734
SR - 4444
POL - H
FEC - 3/4
QPSK
When I scanned it, it labeled RTV east as VIDEO 1 and labeled RTV west
as RTV west.
Also if you have an external module in your reciever, choose the built-in tuner or it
will not pick it up.
You can use this tp when looking for AMC-9. It gets a quality signal of 95%.
TP - 11775
SR - 4232
POL - H
FEC - 5/6
QPSK
New to FTA and need help installing LNB and a few other Questions.
how to fit a seavey feed,on a 3 meter channel master antenna?
