660 is "TBA" | SatelliteGuys.US
660 is "TBA"
SamCdbs
2,745
1,086
Notice that there is now no guide data for DirecTV 660 "Fox Sports Ohio". Its just TBA out into infinity.
DirecTV has had the guide data wrong for as long as I can remember. Fox Sports Ohio has three main feeds. What DirecTV calls "FS Ohio" on 660 is the Cleveland feed, with the NBA Cavs and NHL Blue Jackets (and Foxfiller when the Reds are playing). What DirecTV calls "FS Cincinnati" on 661 is the Cincinnati feed, with the NHL Blue Jackets and MLB Reds (and Foxfiller when the Cavs are playing), but the guide data is that for the Columbus feed, with all three teams. Has always been like that.
Perhaps they have discovered their mistake?
Strange indeed. I don't watch that channel. I watch 661 because it is the Reds channel and I would have to have the Sports Pack to get the other one anyway.
Zip Code is 41102.
The 41102 ZIP Code is in the home team territory for the following pro teams. With HD Access select channels and teams available in HD are noted below:
With any DIRECTV base package (CHOICE or above, or MÁS ULTRA or above):
FSN Cincinnati (Ch. 661) - HD Available
Columbus Blue Jackets (HD Available)
Reds (HD Available)
With the PREMIER or LO MAXIMO package or any DIRECTV base package plus SPORTS Pack, you also get:
FSN South (Ch. 646) - HD Available
Nashville Predators (HD Available)
FSN Midwest (Ch. 671) - HD Available
Indiana Pacers (HD Available)
With the Choice Xtra package you also get:
Sports Time Ohio (Ch. 662) - HD Available
Indians (HD Available)
Ohio seems to be an odd area for RSN's...seems like 3 different packages gives you different RSN's
ramy is a good example and I ran a zip for someone who got FSN Ohio with basic, STO with choice + and FSN Pittsburgh with sports pack
sadly I only get the Twins regardless of package...I get no extra teams with sports pack
The area I live in doesn't really have a home area per se. So that is probably why I get so many with different packages.
yeah you're in a lucky area. Friend of mine is in the same boat. She's in Iowa and gets CSN Chicago with main package but adds the sports pack to get the Twins, Brewers, Royals and Cards for baseball, Blues for hockey and Wolves for B-Ball
Interesting she gets the Wolves but not the Bucks
Zip Code is 41102.
Wow, did you get the shaft ....
The 43623 ZIP Code is in the home team territory for the following pro teams. With HD Access select channels and teams available in HD are noted below:
FSN Ohio (Ch. 660) - HD Available
# Cleveland Cavaliers (HD Available)
# Reds (HD Available)
FSN Detroit (Ch. 663) - HD Available
# Detroit Pistons (HD Available)
# Detroit Red Wings (HD Available)
# Tigers (HD Available)
# Indians (HD Available)
fwiw, I'm not sure why the Blue Jackets are not included in there some where.
I get the Cincy stuff and the Cleveland stuff
Jose Lima passes at 37 years old
Supreme Court: NFL is 32 teams, not single business
