61.5 with 105,110,119 | SatelliteGuys.US
trido
440
17
Southern indiana
Well for today I just added another dish for 61.5 running it directly into 811.
So i hope this works DISH added voom pkg minutes ago.
Said a take a few minutes wuestion should I hook back up my switch 34 with 105,110,119 to get update.
then unhook it and hook up 61.5 dish
or will new info go thru 61.5 sat also
I have a feeling this all wont work since I am not useing a switch now
trido
True - but specifically here, he needs to know that he DOES have a switch - it's implicit with a StupiDish installation. ;)
And if he wants to keep his existing three birds, he'll need to add another switch for 61.5. Either replace the DP34 with a DPP44, or, if he only needs 1-2 tuners to see the 61.5 feed, he can add DP21(s). If two, the 61.5 dish has to have a DP Dual LNBF.
3sat Installation Help Needed!
Can you place order for 2nd dish install over the phone?
