61.5 Spot Beams 13 and 11 | SatelliteGuys.US
intrac
176
I'm getting my locals (Buffalo) on 61.5, Transponder 13 - Spot 4.
I'm also seeing a Spot beam on 11. Where is this?
It seems to come in as strong as my HD locals on 13.
Thanks for any info.
look at "the list" at top of the site maps for all the spots are there.
I would appreciate it if you could post the signal strengths for the spots you receive. They moved the beams a little north and I am working on remapping. Buffalo is one of the areas that I am using as a reference point. I am getting close to having enough data to complete the work but need just a little bit more.
For Nelson61, Buffalo HD Spots come in at 21, (TP13, S4) where if it is Philly (TP11, S4) it comes in at 10 points higher at 31. Seems strange, but looks like a "move is in my future.
Thanks.
Thanks.
It would be great if you could add you SS numbers to the others posted here.
moving dish from 2nd floor to ground
