OK since they are trying to charge me 95 bucks to do this, how easy is it to do myself? And are the hd locals for cleveland on the 129. Last time i checked they weren't.
is sports time ohio on there too?
Don't do a check switch first until you have a signal.
Put the receiver on a transponder on 61.5 that is also active on 129 for HD 8PSK. Mark your settings on the pole so you can go back if you can't find 129.
Move the dish over watching the screen. It will say Wrong satellite, but that's ok. Just make sure it says 129. Tweak the signal and lock everything down.
Then do a check switch.
It lets me select 129 on the point screen. should i just turn it to that then point? if not which transponder should i use on the 61.5 point screen?
Limited time offer
