61.5 or 129 in eastern Washington? | SatelliteGuys.US
ataribaby
2
Pullman, Washington
I recently had an installation of DishHD with two 500 dishes (one exclusively pointed at 129 for the HD channels). However, a wind storm blew that dish down (I know, bad installation) and so they are coming out to re-install that dish. After the initial installation, I realized that there were a few public interest channels exclusively on 61.5 (which also carries the HD channels). I'd like to get Classic Arts Showcase, in particular. So, my questions are:
1) Can I ask the installer to point the dish at 61.5 instead of 129 on the re-install?
2) Will I lose any channels if I do make that switch?
3) Will I see a significant dip in picture quality/signal strength if I go for 61.5 over 129?
4) Is there anything known about the future capacity/reliability of 61.5 vs. 129 that I should consider in this situation?
I'm in Pullman, Washington (which is south of Spokane) so the local channels are on a different satellite (110) and are not affected by this situation.
Thanks for the advice in advance!
- Brett
if you have a line of sight to the satellite they might be able to. 61.5 is pretty low on the west coast (I think like a 12 elevation)
unless you have HD Locals, there is no differencre in the HD channels. You'd gain the HD demo channel on 61.5 :)
61.5 is stronger than 129 so the signal should go up. The only drawback would be rain fade (due to the low elevation)
nothing that I know of. I use 61.5 here in MN and the signals are higher than 129
Fox asks U.S. court to bar EchoStar retransmissions
Survey: Any HD channels that you don't watch?
