6 foot or 8 foot? | SatelliteGuys.US
6 foot or 8 foot?
Blindowl1234
2,035
94
SouthWest Ohio
Ok guys is there much of a signal increase going from a six foot dish to an eight? I'm toying with the idea of maybe switching out the panels etc... No way I can do a 10 footer. It's too difficult to move my 8.5 Paraclipse it's pretty much stuck where it is on 97W. There is a noticable difference between the 6ft Fortec and the 8.5 foot Paraclipse at least on 97W. Blind
Hi, do you have a DVB-S2 receiver and do you like sport feeds? If so bigger is better as I can often just lock the S2 HD feeds. It seems to take over 70% signal Q to lock the 9/10 FEC stuff. If you are not trying to get the S2 feeds then the bigger dish might not pay off. Hope this helps, DC
On my 6 footer here in Minneapolis I get probably 97/98% of the DVB stuff up there
There are some 7/8 FEC channels that are a bugger for me to get.
As DC noted, S2 chanenls are harder to get especially with the 6 footer. I can get some of the stronger items but 9/10 FEC....forget it ;)
I haven't run the link budgets, but I'd go for the 8 foot dish (conditions equal between the 8 and 6 footers) because you'll get a little bit more 2 deg separation of the c-band sats. Ideally 9 or larger is best if the dish is in great shape so you can pull out one c-band sat at a time.
Most S2 signals need to be very clean to receive, so if you have some slight co-satellite interference, you are going to have issues.
seriously, now . . .
. . . There is a noticable difference between the 6ft Fortec and the 8.5 foot Paraclipse at least on 97W.
I think you answered your own question.
This is I did not understand.
There is no dish you can do that on, to my knowledge.
Is this a mesh?
'Cause the only one in that size that comes to mind is the Hydro.
And if you -have- a Hydro, go find a proper H-H motor for it!!!
Second choice, go dish-hunting for a nice 8'er.
Just drive around, take notes, and then ask at the best houses.
Lots of us got outstanding dishes that way!
Thanks Guys. With the six footer I get some of the stronger S2 network stuff. No RTV on 87W barely a beep on either T.P on that one. Anole my thought was to switch the panels on a Fortec from a six to eight foot..I'd have to change the mount for the lnb etc...focal distance etc.... Then I'd do away with the Paraclipse altogether. The Paraclipse needs a decent post $35...not counting concrete. Acuator at over $100. So I figure I'd have another $150 in that old dish. Yep its a mesh. I'm guessing its a classic? I looked at a bunch of pictures but the size of my vintage 1985 model Paraclipse doesn't exist. Oh well maybe for the cost I'll look for a larger B.U.D ...oh the wife will love me for that one! lol....Blind:)
old birdview
another 922 saved.
