H havenx SatelliteGuys Pro Original poster Sep 1, 2005 211 0 Jun 19, 2006 #1 This is pretty much a question for Ice, but if anyone else knows post. What size mast does the normal 6 foot BUD use?
Tron SatelliteGuys Master May 6, 2005 6,599 35 Metro New Orleans, LA Jun 19, 2006 #2 Judging from the BUD I was playing with tonight, it looks to be 3.5" - 4" diameter. Last edited: Jun 19, 2006
M Mr Tony SatelliteGuys Pro Supporting Founder Nov 17, 2003 3,429 15,031 Mankato, MN Jun 19, 2006 #3 Mine doesn't use a mast. it has a frame that you build (since this doesn't get buried). I think normal C-band masts are 3 1/2" minimum
I i4tas SatelliteGuys Pro Sep 10, 2005 791 4 Northern USA Jun 19, 2006 #4 This Thread A While Back was about c-band poles: http://www.satelliteguys.us/showthread.php?t=40491&page=4 I traced my dishes pole mount on a piece of paper so i could tell the exact diameter and went to a welding shop that had several poles/pipes and used my paper to make sure i got the right one.
S sksatellite SatelliteGuys Pro Sep 7, 2003 616 0 Jun 19, 2006 #5 A 6 footer use 2.5" or 3" inch outside dimension pole. depend the maker.
DK_Sat SatelliteGuys Pro Dec 11, 2005 572 14 MD Jun 19, 2006 #6 My 2 Winegard 6.3" Mash dishes the polar mount is 3.5 My KTI 5.9" Mash dish the polar mount is adjustable from 2.5 to 3.5 Last edited: Jun 19, 2006
