6.3 Remote Keeps sticking | SatelliteGuys.US
bluejonah
usa
Im using a 6.3 remote, when I move through individual channels the remote seems to stick and keeps moving through channels or cycling through menus over and over. ive cleaned ait and that didnt seem to fix it. any solutions/ideas?
Rubbing alcohol shouldn't hurt the remote and is good at removing gunk. Or take it apart and you will probably find the rubber buttons inside are dirty.
important question
Grounding dish & system > 200 ft apart
