40.0 remote issue | SatelliteGuys.US
40.0 remote issue
300mag
207
69
I'm having same issue on 2 of my 40.0 remotes paired on H3 and Joey. When I hit the TV button(to change TV input) the tv light flashes 4 times rapidly(not the continuous flashing when you hold to set tv code for older receivers) and switches back to sat. The remote shows paired to H3 and to correct tv model and volume works but just won't switch to TV mode. Is there was to reset remote after I impair? Or other way to fix?
Sent from my H1611 using Tapatalk
Use the 40 remote and go into remote settings and turn off limited mode.
Thx that was the issue it appears after u341 update the H3 and 2 out 3 Joey's switched to limited mode.
Reactions: Rainy99
WJ losing WAP nightly
Have Sat TV - Who provides your internet service.
