4/13/2016 13:35 - Uplink Report - 34 Changes | SatelliteGuys.US
Uplink PC
Uplink Report PC
707
6
SatelliteGuys.US DishNetwork Uplink Report - 4/13/2016 13:35 - 34 Changes
Uplink Comparison Range: 4/13/2016 13:29 - 4/13/2016 13:35 (PST)
Channel Additions:
525 - DEMND [MPEG4 SD] added to Nimiq5 72.7W TP 07 ConUS (DEMND)(A)
525 - DEMND [MPEG2 SD] added to EchoStar11 110W TP 09 ConUS (DEMND)(A)
4252 - INT9 [MPEG4 HD] added to Echostar16 61.5W TP 01 Conus (INT9)(NA)(H)
4253 - INT1 [MPEG4 HD] added to Echostar16 61.5W TP 01 Conus (INT1)(NA)(H)
4254 - INT2 [MPEG4 HD] added to Echostar16 61.5W TP 01 Conus (INT2)(NA)(H)
4255 - INT3 [MPEG4 HD] added to Echostar16 61.5W TP 01 Conus (INT3)(NA)(H)
4256 - INT4 [MPEG4 HD] added to Echostar16 61.5W TP 01 Conus (INT4)(NA)(H)
4257 - INT5 [MPEG4 HD] added to Echostar16 61.5W TP 01 Conus (INT5)(NA)(H)
4258 - INT6 [MPEG4 HD] added to Echostar16 61.5W TP 01 Conus (INT6)(NA)(H)
4259 - INT7 [MPEG4 HD] added to Echostar16 61.5W TP 01 Conus (INT7)(NA)(H)
4260 - INT8 [MPEG4 HD] added to Echostar16 61.5W TP 01 Conus (INT8)(NA)(H)
4261 - INT10 [MPEG4 HD] added to Echostar16 61.5W TP 01 Conus (INT10)(NA)(H)
5165(8) - WBPN [MPEG4 HD] added to Echostar16 61.5W TP 32 Spotbeam 02 (WBPN)(Mkt: Binghamton,NY)(NA)(H)
6605(8) - WBPN [MPEG2 SD] added to EchoStar14 119W TP 01 Spotbeam A15 (WBPN)(Mkt: Binghamton,NY)(NA)(H)
8313(32) - WGTA [MPEG4 SD] added to Echostar16 61.5W TP 21 Spotbeam 59 (WGTA)(Mkt: Atlanta,GA)(NA)(H)
8313(32) - WGTA [MPEG2 SD] added to EchoStar14 119W TP 01 Spotbeam A17 (WGTA)(Mkt: Atlanta,GA)(NA)(H)
19901 - BMG02 [af] added to Anik F3 118.7W TP 07 ConUS (BMG02)(NA)(H)
19901 - BMG02 [af] added to EchoStar14 119W TP 19 ConUS (BMG02)(NA)(H)
19901 - BMG02 [af] added to Nimiq5 72.7W TP 21 ConUS (BMG02)(NA)(H)
19902 - BMG03 [af] added to Anik F3 118.7W TP 07 ConUS (BMG03)(NA)(H)
19902 - BMG03 [af] added to EchoStar14 119W TP 19 ConUS (BMG03)(NA)(H)
19902 - BMG03 [af] added to Nimiq5 72.7W TP 21 ConUS (BMG03)(NA)(H)
19910 - BMG11 [af] added to Anik F3 118.7W TP 07 ConUS (BMG11)(NA)(H)
19910 - BMG11 [af] added to EchoStar14 119W TP 19 ConUS (BMG11)(NA)(H)
19910 - BMG11 [af] added to Nimiq5 72.7W TP 21 ConUS (BMG11)(NA)(H)
19918 - BMG18 [af] added to Anik F3 118.7W TP 07 ConUS (BMG18)(NA)(H)
19918 - BMG18 [af] added to EchoStar14 119W TP 19 ConUS (BMG18)(NA)(H)
19918 - BMG18 [af] added to Nimiq5 72.7W TP 21 ConUS (BMG18)(NA)(H)
19919 - BMG19 [af] added to Anik F3 118.7W TP 07 ConUS (BMG19)(NA)(H)
19919 - BMG19 [af] added to EchoStar14 119W TP 19 ConUS (BMG19)(NA)(H)
19919 - BMG19 [af] added to Nimiq5 72.7W TP 21 ConUS (BMG19)(NA)(H)
Channel Removals:
9926 - INFO [MPEG2 SD] (A)(H) removed from Anik F3 118.7W TP 01 ConUS (Dish Network Information Channel)
15199 - WVLA2 [Guide Data] (NA)(H) removed from EchoStar10 110W TP 25 Spotbeam 12 (WVLA2)
Name Changed:
684 - PLYMX [MPEG2 SD] Anik F3 118.7W TP 25 ConUS renamed to AAJET (AAJET)(A)(H)
Transponder Changes:
EchoStar14 119W TP 19 ConUS (21.500 8PSK 2/3) added.
Anik F3 118.7W TP 07 ConUS (20.000 QPSK 3/4) added.
Echostar16 61.5W TP 32 Spotbeam 02 (21.500 8PSK 3/4) added.
Echostar16 61.5W TP 21 Spotbeam 59 (21.500 8PSK 3/4) added.
EchoStar14 119W TP 01 Spotbeam A15 (21.500 8PSK 2/3) added.
EchoStar14 119W TP 01 Spotbeam A17 (20.000 QPSK 7/8) added.
Anik F3 118.7W TP 01 ConUS (20.000 QPSK 3/4) removed.
EchoStar10 110W TP 25 Spotbeam 12 (20.000 QPSK 5/6) removed.
Channels in the system: 9726
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
(FP) = Free Preview
The Format and Layout of the SatelliteGuys Uplink Report is © Copyright 2014 SatelliteGuys.US and may not be republished without written permission from SatelliteGuys.US.
SatelliteGuys Uplink PC Version 1.0.1
© 2014 - All Rights Reserved - SatelliteGuys Incorporated
Nope...
Look Blugras more Test Channels. :)
yea i noticed that scott i wonder what dish is going to do with all this test channels?very good question to ask?and if these are right with these test hd channels these must be national hd channels going on eastern arc.
Nothing will go to eastern arc that doesn't go to western arc as well. It's more like let's test 10 HD channels on a single transponder using 'this' particular compression technique.... ;)
4/11/2016 09:00 - Uplink Report - 2 Changes
4/14/2016 10:19 - Uplink Report - 3 Changes
