4/06/2015 03:15 - Uplink Report - 48 Changes | SatelliteGuys.US
Uplink PC
Uplink Report PC
707
6
SatelliteGuys.US DishNetwork Uplink Report - 4/06/2015 03:15 - 48 Changes
Uplink Comparison Range: 4/06/2015 03:08 - 4/06/2015 03:15 (PST)
Channel Moves:
900 - MLB [MPEG4 SD] Nimiq5 72.7W TP 07 ConUS moved to Echostar16 61.5W TP 09 Conus (MLB)(A)(H)
900 - MLB [MPEG2 SD] EchoStar14 119W TP 11 ConUS moved to EchoStar14 119W TP 12 ConUS (MLB)(A)(H)
901 - MLB [MPEG2 SD] EchoStar14 119W TP 17 ConUS moved to EchoStar14 119W TP 18 ConUS (MLB)(A)(H)
901 - MLB [MPEG4 SD] Nimiq5 72.7W TP 07 ConUS moved to Nimiq5 72.7W TP 09 ConUS (MLB)(A)(H)
902 - MLB [MPEG2 SD] EchoStar14 119W TP 17 ConUS moved to EchoStar14 119W TP 11 ConUS (MLB)(A)(H)
903 - MLB [MPEG4 SD] Nimiq5 72.7W TP 07 ConUS moved to Nimiq5 72.7W TP 29 ConUS (MLB)(A)(H)
903 - MLB [MPEG2 SD] EchoStar14 119W TP 17 ConUS moved to EchoStar11 110W TP 24 ConUS (MLB)(A)(H)
904 - MLB [MPEG2 SD] EchoStar14 119W TP 17 ConUS moved to EchoStar14 119W TP 12 ConUS (MLB)(A)(H)
905 - MLB [MPEG2 SD] EchoStar14 119W TP 17 ConUS moved to EchoStar14 119W TP 21 ConUS (MLB)(A)(H)
905 - MLB [MPEG4 SD] Nimiq5 72.7W TP 07 ConUS moved to Nimiq5 72.7W TP 05 ConUS (MLB)(A)(H)
906 - MLB [MPEG2 SD] EchoStar14 119W TP 17 ConUS moved to EchoStar14 119W TP 21 ConUS (MLB)(A)(H)
906 - MLB [MPEG4 SD] Nimiq5 72.7W TP 07 ConUS moved to Nimiq5 72.7W TP 09 ConUS (MLB)(A)(H)
907 - MLB [MPEG2 SD] EchoStar14 119W TP 17 ConUS moved to EchoStar14 119W TP 21 ConUS (MLB)(A)(H)
907 - MLB [MPEG4 SD] Nimiq5 72.7W TP 07 ConUS moved to Nimiq5 72.7W TP 05 ConUS (MLB)(A)(H)
908 - MLB [MPEG4 SD] Nimiq5 72.7W TP 07 ConUS moved to Nimiq5 72.7W TP 25 ConUS (MLB)(A)(H)
908 - MLB [MPEG2 SD] EchoStar14 119W TP 17 ConUS moved to EchoStar11 110W TP 16 ConUS (MLB)(A)(H)
909 - MLB [MPEG2 SD] EchoStar14 119W TP 17 ConUS moved to EchoStar14 119W TP 11 ConUS (MLB)(A)(H)
909 - MLB [MPEG4 SD] Nimiq5 72.7W TP 07 ConUS moved to Nimiq5 72.7W TP 05 ConUS (MLB)(A)(H)
910 - MLB [MPEG2 SD] EchoStar14 119W TP 17 ConUS moved to EchoStar14 119W TP 18 ConUS (MLB)(A)(H)
910 - MLB [MPEG4 SD] Nimiq5 72.7W TP 07 ConUS moved to Nimiq5 72.7W TP 09 ConUS (MLB)(A)(H)
911 - MLB [MPEG4 SD] Nimiq5 72.7W TP 07 ConUS moved to Nimiq5 72.7W TP 29 ConUS (MLB)(A)(H)
911 - MLB [MPEG2 SD] EchoStar14 119W TP 17 ConUS moved to EchoStar11 110W TP 24 ConUS (MLB)(A)(H)
912 - MLB [MPEG2 SD] EchoStar14 119W TP 17 ConUS moved to EchoStar14 119W TP 12 ConUS (MLB)(A)(H)
912 - MLB [MPEG4 SD] Nimiq5 72.7W TP 07 ConUS moved to Nimiq5 72.7W TP 09 ConUS (MLB)(A)(H)
913 - MLB [MPEG2 SD] EchoStar14 119W TP 17 ConUS moved to EchoStar14 119W TP 21 ConUS (MLB)(A)(H)
913 - MLB [MPEG4 SD] Nimiq5 72.7W TP 07 ConUS moved to Nimiq5 72.7W TP 22 ConUS (MLB)(A)(H)
914 - MLB [MPEG4 SD] Nimiq5 72.7W TP 07 ConUS moved to Nimiq5 72.7W TP 09 ConUS (MLB)(A)(H)
914 - MLB [MPEG2 SD] EchoStar14 119W TP 17 ConUS moved to EchoStar11 110W TP 16 ConUS (MLB)(A)(H)
5101(900) - MLB [MPEG4 HD] Nimiq5 72.7W TP 08 ConUS moved to Nimiq5 72.7W TP 10 ConUS (MLB)(A)(H)
5101(900) - MLB [MPEG4 HD] Ciel-2 129W TP 25 ConUS moved to Ciel-2 129W TP 26 ConUS (MLB)(A)(H)
5102(901) - MLB [MPEG4 HD] Nimiq5 72.7W TP 08 ConUS moved to Nimiq5 72.7W TP 10 ConUS (MLB)(A)(H)
5102(901) - MLB [MPEG4 HD] Ciel-2 129W TP 25 ConUS moved to Ciel-2 129W TP 26 ConUS (MLB)(A)(H)
5103(902) - MLB [MPEG4 HD] Nimiq5 72.7W TP 08 ConUS moved to Nimiq5 72.7W TP 10 ConUS (MLB)(A)(H)
5103(902) - MLB [MPEG4 HD] Ciel-2 129W TP 25 ConUS moved to Ciel-2 129W TP 26 ConUS (MLB)(A)(H)
5104(903) - MLB [MPEG4 HD] Nimiq5 72.7W TP 08 ConUS moved to Nimiq5 72.7W TP 10 ConUS (MLB)(A)(H)
5104(903) - MLB [MPEG4 HD] Ciel-2 129W TP 25 ConUS moved to Ciel-2 129W TP 26 ConUS (MLB)(A)(H)
5105(904) - MLB [MPEG4 HD] Nimiq5 72.7W TP 08 ConUS moved to Nimiq5 72.7W TP 10 ConUS (MLB)(A)(H)
5105(904) - MLB [MPEG4 HD] Ciel-2 129W TP 25 ConUS moved to Ciel-2 129W TP 26 ConUS (MLB)(A)(H)
5107(906) - MLB [MPEG4 HD] Nimiq5 72.7W TP 08 ConUS moved to Nimiq5 72.7W TP 01 ConUS (MLB)(A)(H)
5107(906) - MLB [MPEG4 HD] Ciel-2 129W TP 25 ConUS moved to Ciel-2 129W TP 27 ConUS (MLB)(A)(H)
5108(907) - MLB [MPEG4 HD] Ciel-2 129W TP 25 ConUS moved to EchoStar14 119W TP 07 ConUS (MLB)(A)(H)
5108(907) - MLB [MPEG4 HD] Nimiq5 72.7W TP 08 ConUS moved to Nimiq5 72.7W TP 01 ConUS (MLB)(A)(H)
5109(908) - MLB [MPEG4 HD] Nimiq5 72.7W TP 08 ConUS moved to Nimiq5 72.7W TP 01 ConUS (MLB)(A)(H)
5109(908) - MLB [MPEG4 HD] Ciel-2 129W TP 25 ConUS moved to Ciel-2 129W TP 27 ConUS (MLB)(A)(H)
5111(910) - MLB [MPEG4 HD] Nimiq5 72.7W TP 08 ConUS moved to Nimiq5 72.7W TP 10 ConUS (MLB)(A)(H)
5111(910) - MLB [MPEG4 HD] Ciel-2 129W TP 25 ConUS moved to Ciel-2 129W TP 26 ConUS (MLB)(A)(H)
5113(912) - MLB [MPEG4 HD] Nimiq5 72.7W TP 08 ConUS moved to Nimiq5 72.7W TP 01 ConUS (MLB)(A)(H)
5113(912) - MLB [MPEG4 HD] Ciel-2 129W TP 25 ConUS moved to Ciel-2 129W TP 27 ConUS (MLB)(A)(H)
Transponder Changes:
Echostar16 61.5W TP 09 Conus (21.500 8PSK 2/3) added.
EchoStar11 110W TP 16 ConUS (20.000 QPSK 7/8) added.
Nimiq5 72.7W TP 22 ConUS (21.500 8PSK 2/3) added.
Nimiq5 72.7W TP 25 ConUS (21.500 8PSK 2/3) added.
EchoStar14 119W TP 17 ConUS (20.000 QPSK 7/8) removed.
Channels in the system: 9685
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
(FP) = Free Preview
The Format and Layout of the SatelliteGuys Uplink Report is © Copyright 2014 SatelliteGuys.US and may not be republished without written permission from SatelliteGuys.US.
SatelliteGuys Uplink PC Version 1.0.0
© 2014 - All Rights Reserved - SatelliteGuys Incorporated
4/03/2015 23:40 - Uplink Report - 12 Changes
4/01/2015 12:44 - Uplink Report - 143 Changes
