4/01/2016 12:44 - Uplink Report - 18 Changes | SatelliteGuys.US
Uplink PC
Uplink Report PC
707
6
SatelliteGuys.US DishNetwork Uplink Report - 4/01/2016 12:44 - 18 Changes
Uplink Comparison Range: 4/01/2016 12:41 - 4/01/2016 12:44 (PST)
MAP Changed:
5816(16) - LOCAL [MPEG4 SD] Nimiq5 72.7W TP 30 ConUS renamed to DISH , changed to Not Available , map (16) removed (Dish Network Information Channel)(NA)(H)
5816(16) - LOCAL [MPEG2 SD] EchoStar11 110W TP 21 ConUS renamed to DISH , changed to Not Available , map (16) removed (Dish Network Information Channel)(NA)(H)
5817(12) - LOCAL [MPEG4 SD] Nimiq5 72.7W TP 30 ConUS renamed to DISH , changed to Not Available , map (12) removed (Dish Network Information Channel)(NA)(H)
5817(12) - LOCAL [MPEG2 SD] EchoStar11 110W TP 21 ConUS renamed to DISH , changed to Not Available , map (12) removed (Dish Network Information Channel)(NA)(H)
5818(28) - LOCAL [MPEG4 SD] Nimiq5 72.7W TP 30 ConUS renamed to DISH , changed to Not Available , map (28) removed (Dish Network Information Channel)(NA)(H)
5818(28) - LOCAL [MPEG2 SD] EchoStar11 110W TP 21 ConUS renamed to DISH , changed to Not Available , map (28) removed (Dish Network Information Channel)(NA)(H)
5819(2) - LOCAL [MPEG4 SD] Nimiq5 72.7W TP 30 ConUS renamed to DISH , changed to Not Available , map (2) removed (Dish Network Information Channel)(NA)(H)
5819(2) - LOCAL [MPEG2 SD] EchoStar11 110W TP 21 ConUS renamed to DISH , changed to Not Available , map (2) removed (Dish Network Information Channel)(NA)(H)
5820(28) - LOCAL [MPEG4 SD] Nimiq5 72.7W TP 30 ConUS renamed to DISH , changed to Not Available , map (28) removed (Dish Network Information Channel)(NA)(H)
5820(28) - LOCAL [MPEG2 SD] EchoStar11 110W TP 21 ConUS renamed to DISH , changed to Not Available , map (28) removed (Dish Network Information Channel)(NA)(H)
5821(28) - LOCAL [MPEG4 SD] Nimiq5 72.7W TP 30 ConUS renamed to DISH , changed to Not Available , map (28) removed (Dish Network Information Channel)(NA)(H)
5821(28) - LOCAL [MPEG2 SD] EchoStar11 110W TP 21 ConUS renamed to DISH , changed to Not Available , map (28) removed (Dish Network Information Channel)(NA)(H)
5822(2) - LOCAL [MPEG4 SD] Nimiq5 72.7W TP 30 ConUS renamed to DISH , changed to Not Available , map (2) removed (Dish Network Information Channel)(NA)(H)
5822(2) - LOCAL [MPEG2 SD] EchoStar11 110W TP 21 ConUS renamed to DISH , changed to Not Available , map (2) removed (Dish Network Information Channel)(NA)(H)
5823(24) - LOCAL [MPEG4 SD] Nimiq5 72.7W TP 30 ConUS renamed to DISH , changed to Not Available , map (24) removed (Dish Network Information Channel)(NA)(H)
5823(24) - LOCAL [MPEG2 SD] EchoStar11 110W TP 21 ConUS renamed to DISH , changed to Not Available , map (24) removed (Dish Network Information Channel)(NA)(H)
5824(16) - LOCAL [MPEG4 SD] Nimiq5 72.7W TP 30 ConUS renamed to DISH , changed to Not Available , map (16) removed (Dish Network Information Channel)(NA)(H)
5824(16) - LOCAL [MPEG2 SD] EchoStar11 110W TP 21 ConUS renamed to DISH , changed to Not Available , map (16) removed (Dish Network Information Channel)(NA)(H)
Channels in the system: 9716
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
(FP) = Free Preview
The Format and Layout of the SatelliteGuys Uplink Report is © Copyright 2014 SatelliteGuys.US and may not be republished without written permission from SatelliteGuys.US.
SatelliteGuys Uplink PC Version 1.0.1
© 2014 - All Rights Reserved - SatelliteGuys Incorporated
4/01/2016 14:20 - Uplink Report - 1 Change
3/29/2016 18:00 - Uplink Report - 38 Changes
