3LNB Dish? | SatelliteGuys.US
3LNB Dish?
enricong
119
9
I just placed an order for Direct TV getting the Plus HD DVR package.
I live in South Jersey near Philly.
I got my order confirmation and it says "1 3 LNB ? SL3S" under equipment.
Does this mean I am getting a 3 LNB dish? I thought that I would need a 5LNB dish based on looking at the transponder tables.
Is this something I need to call up and correct or will the installer know what to do?
The installer will know what to do. If all of your receivers are HD, and your locals are from Philly, the 3LNB dish will be fine.
Actually, you are getting the NEW 3 lnb set up that points at just the main three sats now, thtas all that is needed for the most part, they are the core programming and the MPEG4 sats.
99, 101 and 103.
The order is correct. SL3 is the new one.
Jimbo
D-11 receiver?
Media Share that works with .mpg and divx
