I see on 3ABN's website that the $50 dish is listed as a 36" dish. I read the directions that is posted in their system listing, and it says it is 32"/ Does anyone know for sure that this is a 36" dish? Thanks in advance!
The width is the measurement to go by. Since the dish is an offset dish, the height will be larger for it appears to the signal to be a round dish. Ideally the db gain would be the factor to compare with others as you will want to know how much signal you are going to collect.
I believe the biggest single thing that effects reception on these stamped metal dishes is warpage or "clam-shelling" damage from shipping.I think in the end, any difference in size is far less important than the other accumulated inaccuracies ...
...or the mistakes we make.
Some good points in this thread... Absolutely correct, in the final analysis, it is signal gain which determines the merit of any dish. I do like the Azure Shine dishes sold by 3ABN and SatelliteAV, due to their rugged construction.
Limited time offer
