32apsk receivers anyone testing them | SatelliteGuys.US
madmadworld
Official TV Watcher
17,110
6,973
up on the roof in SinCity
seeing these 32apsk feeds about anyone get anything with any of these boxes only ones I've found.
LinkBox 8000, Clarke Tech 4100 HD, Dr.HD D15.
any others I'm missing ?
a few pc cards out there.
Here is Demod spec's for the Clark Tech unit....
Demodulator
Front end DVB-S/S2 QPSK, 8PSK, 16APSK, 32APSK
Symbol rate DVB-S : 2~45Msps, DVB-S2 : 10~30Msps(QPSK) 10~30Msps(8PSK)36Msps(16APSK), 27Msps(32APSK)
Spectral inversion Auto conversion
The 32apsk TPs I lock have Scan Rates of 30M and 34M
The GEOSATpro microHD has been tested on the bench for 32APSK, but have never found a live satellite feed to verify in the real world.
The new HDVR1200 will support the same: 32apsk @ 27Msps, 16apsk @36Msps, QPSK/8psk/H8psk @45Msps.
Pixl,
Several microHD owners asking about any channels to test on. Any 24/7 32apsk feeds that can be shared in the open forum?
One member PMed an occasional feed, but I wont be able to test for several weeks due to my schedule.
I have read numerous reports that the microHD locks on live 32APSK services, but I have only tested and verified on the bench. If the Manhattan RS1933 locks live 32apsk, the microHD would also.
I have not found a 24/7 feed. Only see the occasional temp feed, but they are sometimes up over a weekend. I scan for some fresh ones and post here if I find any.
Would they be the ones that have modulation of "HSBC" or something like that on the MicroHD?
Well disappointing, I was PM'd a up and running 328PSK feed from another member. Either I'm mistaken about the Manhattan RS 1933 able to see this or my 8' dish and Norsat ortho feed set up isn't good enough for this service. This was on 87C and most all TP's come in at high levels. :(
Either I'm mistaken about the Manhattan RS 1933 able to see this or my 8' dish and Norsat ortho feed set up isn't good enough for this service.. :(
No opinion on the receiver, but I think the dish/ortho/LNB combination fall way short. :(
Not finding anything 32PSK on 87 with a blind scan (microHD). Maybe the 10' dish won't p/u either.
At this time, the HDVR1200 public release firmware has limited implementation of FTA features and functions. There are several folks providing advanced testing with development firmware. We have a NDA in effect with these individuals until the FTA firmware is released.
FYI, a lot of 16 and 32spk signals showing up on AMC9 83w C-band;
interested to know if anyone can process these and what receiver you used?
Brian, maybe you can use these signals for your testing...
2Q==
Hello everybody,
I'm from Turkey.
I'm sorry for bad English :(
But none of this does not send to Turkey.
How do i get one of these ?
Hopefully,you understand to me
EPG on Galaxy 19 (97W) Ku
Firmware Convert Motorola DSR-605
