30w dropping channels? | SatelliteGuys.US
jogon64
199
Northern Mexico
I just blind scanned 30w on a pansat 3500 and noticed some changes.
RCI is gone.
Telecaribe Colombia and Zoom are now at 11934 V 5250.
Tps 12130 H 27500, 12170 H 27500 and 12092 H 27500 with all the arab programming are gone as well.
I do not think they are gone like you say. As a matter of fact a new channel in spanish Pasiones , soap operas 24x7 , just started on the overon mux at 12172H 27500. The KTV's are still there but the pixellate constantly for several days now, the arab mux at 12132H is still there and the new portyuguese TVI and CGN are still there as well. You might have an issue with your horizontal polarity since you get none of them apparently , give more details of your setup and we will gladly help you further. RCI you are right is gone.
12092 Q is intermittently going to 7 then returns to normal 72-75. pixelation and audio breakup.
12130 is normal here 72-75 Q
12170 is normal here 72-75 Q
Confirm the SR change on 11934 V to 5250
RCI - not in the 11934 mux nor anywhere else on the sat.
Would have checked earlier, but the RPI UND hockey game was on.
Openbox S9, fixed 1.2CM - Ah La BV spoon config.
Pansat 4500 PVR OTA Antenna Setup
Openbox S9 and AZBox Pics ?
