I currently have a 3LNB installed on the eave (facia board) of my house. Is there any reason why a 5 LNB can't be mounted in the same place? Is it that much bigger or heavier? Can I use support brackets screwed into the roof?
It is much heavier mine had to go on top of a small storage room attached to the house.I currently have a 3LNB installed on the eave (facia board) of my house. Is there any reason why a 5 LNB can't be mounted in the same place? Is it that much bigger or heavier? Can I use support brackets screwed into the roof?
Dtv is installing. I found that many agree that it's much bigger and heavier, and facia board won't do. I'm thinking of scabbing a piece of board (probably a 2x8) across the truss beams or putting a pole in the ground that would be braced up top by the eave.
Do you happen to have a photo of the new S-tube mount?
Limited time offer
