3 Remotes on TV2, some on band a, some on B | SatelliteGuys.US
Barry Erick
1,020
Dallas
I have a 21.0 remote, a 6.0 ir/uhfpro and a 6.3 ir/uhf pro remote. The 21 has a switch for ir/uhf inside only. When I started programming this, it was on band A but it is stuck on Band B, now. The 5.3 has a band A_B switch and is fine. Th 6.0 has no switch and is stuck on Band A. So I have a problem with the 6.0 as the 21.0 is a learning remote and the only way I can program the digital switch I have. Is there anyway to change the band for the 21.0 remote or the 6.0 remote?
______________________________________________________________
Found a thread on this, not using forum search but google search on the same terms got the answer in the first post: Even channels are BAND B, odd are BAND A. Easy fix. Too bad Dish does not include and hint of a BAND in their instructions.
Yes, I did find that on the 21.0 I really like that remote and at a very low cost, I may try another one in the Kitchen where I can't find the TV code. Since the 21 is a LEARNING remote, it is simple to take the IR fromt he tv's remote, and learn it on the 21. No codes....
Any Way to Salvage Programming from Dying Receiver
EHD for 211K?
