Was considering putting a dish at vacation house for 1, may be 2 receivers, to recevie South Florida programming...(Miami?)
Want to make this simple and was wondering I needed a 3 LNB or 5LNB dish?
Thanks.
There is no DIRECTV national programming at 110W.If you want any of the programming on 110 or 119, then you need a 5 lnb. Otherwise, the 3 lnb will be fine.
What you miss is a couple of music channels.
If you're going to use an SD receiver, the SL3 is probably a bad idea.
The stranded Sonic Tap channels in question are found at 119W.So music channels don't count as national programming?
My reference to content at 110W had nothing to do with content found at 119W. You are covered, but it is by egg on your face.Well, since I said 110 OR 119, and you can't get only 119 without trying really hard, I'd say I had it covered.
Why is it a bad idea ??
I'd say put up a Slimline now because the OP will eventually have an HDTV at the vacation home.
re: nothing on 110...
I have an SL5 that cannot see 119* but can see 110... I've noticed that the old channels in the 70's show up and show "blacked out in your area" and not "searching for signal" like it does for the obvious 119* channels... does that mean that they are still showing these channels, but just marking them as blacked out?
I know it's a technicality--but I didn't think the FCC allowed them to just leave their satellites empty. Are they still full of MPEG2 HD, but just not accessible anymore?
--Nat
DISH Network and DIRECTV don't share the satellites; they share the slots.FYI, DirecTV only has authorization to use TPs 22-32 on 119 and 28, 30, and 32 on 110. So those sats aren't empty.
I believe Dish uses the others.
DIRECTV's own transponder mapping shows that the MPEG2 HD channels are still there:
ESPN HD (TP12)
ESPN2 HD (TP10)
HBOE HD (TP10)
HD Net (TP8)
HD Theater (TP12)
TNT HD (TP8)
edit: As you point out, these aren't even DIRECTV's TPNs.
As I made abundantly clear, DIRECTV is the entity who is claiming those channels are still up there.If they are still on the satellite, they aren't making it to the receivers. I'll bet you already knew that.
That's why I only identified the sats by their slot location and not their nomenclature.DISH Network and DIRECTV don't share the satellites; they share the slots....
I appreciiate all the input, but my head is spinning....
Is there a way to determine the programming for DirecTV on 110 and 119 for the South Florida area so I can see if I need the 5 LNB?
And do they regularly change the programming on these bands?
Thanks again..
Limited time offer
