3 LNB Problem - Still | SatelliteGuys.US
jkesler24
3
Have new oval/triple lnb. only three lines being run from dish into home with off-air antenna feed added. question, if i get a 5x8 multiswitch and run the 3 lines in, will all receivers in house get good reception? in other words, is it necessary to run all four lines from the dish to the multiswitch?? thanks again for everyone's help.
jonathan
Yes, if you connect a multiswitch to your dish, you need to connect all 4 lines from the dish to the new multiswitch. A 5X8 will allow for the OTA antenna.
showtime
TivoToGo
