3/31/2016 18:45 - Uplink Report - 20 Changes | SatelliteGuys.US
Uplink PC
Uplink Report PC
707
6
SatelliteGuys.US DishNetwork Uplink Report - 3/31/2016 18:45 - 20 Changes
Uplink Comparison Range: 3/31/2016 18:39 - 3/31/2016 18:45 (PST)
MAP Changed:
4971(8) - LOCAL [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to DISH , changed to Not Available , map (8) removed (Dish Network Information Channel)(NA)(H)
4971(8) - LOCAL [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to DISH , changed to Not Available , map (8) removed (Dish Network Information Channel)(NA)(H)
4972(24) - LOCAL [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to DISH , changed to Not Available , map (24) removed (Dish Network Information Channel)(NA)(H)
4972(24) - LOCAL [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to DISH , changed to Not Available , map (24) removed (Dish Network Information Channel)(NA)(H)
4973(31) - LOCAL [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to DISH , changed to Not Available , map (31) removed (Dish Network Information Channel)(NA)(H)
4973(31) - LOCAL [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to DISH , changed to Not Available , map (31) removed (Dish Network Information Channel)(NA)(H)
4974(10) - LOCAL [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to DISH , changed to Not Available , map (10) removed (Dish Network Information Channel)(NA)(H)
4974(10) - LOCAL [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to DISH , changed to Not Available , map (10) removed (Dish Network Information Channel)(NA)(H)
4975(26) - LOCAL [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to DISH , changed to Not Available , map (26) removed (Dish Network Information Channel)(NA)(H)
4975(26) - LOCAL [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to DISH , changed to Not Available , map (26) removed (Dish Network Information Channel)(NA)(H)
4976(12) - LOCAL [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to DISH , changed to Not Available , map (12) removed (Dish Network Information Channel)(NA)(H)
4976(12) - LOCAL [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to DISH , changed to Not Available , map (12) removed (Dish Network Information Channel)(NA)(H)
4977(8) - LOCAL [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to DISH , changed to Not Available , map (8) removed (Dish Network Information Channel)(NA)(H)
4977(8) - LOCAL [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to DISH , changed to Not Available , map (8) removed (Dish Network Information Channel)(NA)(H)
4978(12) - LOCAL [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to DISH , changed to Not Available , map (12) removed (Dish Network Information Channel)(NA)(H)
4978(12) - LOCAL [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to DISH , changed to Not Available , map (12) removed (Dish Network Information Channel)(NA)(H)
4979(3) - LOCAL [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to DISH , changed to Not Available , map (3) removed (Dish Network Information Channel)(NA)(H)
4979(3) - LOCAL [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to DISH , changed to Not Available , map (3) removed (Dish Network Information Channel)(NA)(H)
4980(10) - LOCAL [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to DISH , changed to Not Available , map (10) removed (Dish Network Information Channel)(NA)(H)
4980(10) - LOCAL [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to DISH , changed to Not Available , map (10) removed (Dish Network Information Channel)(NA)(H)
Channels in the system: 9716
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
(FP) = Free Preview
The Format and Layout of the SatelliteGuys Uplink Report is © Copyright 2014 SatelliteGuys.US and may not be republished without written permission from SatelliteGuys.US.
SatelliteGuys Uplink PC Version 1.0.1
© 2014 - All Rights Reserved - SatelliteGuys Incorporated
3/30/2016 16:00 - Uplink Report - 1 Change
3/31/2016 21:00 - Uplink Report - 3 Changes
