2 remotes on 1 TV/Receiver | SatelliteGuys.US
tzer
3
IN
Tried a search and couldn't find anything...
Is it possible to have 2 separate Dish remotes control the same receiver, and if so, how do I set it up?
I want to have 2 remotes in the living room, controlling the sat box for the living room tv at the same time, one for me, one for the wife.
I have a 722k...
Yes, as long as the remote address is the same.
How do I set it up?
I bought a new set of 2 remotes (1 IR, 1 UHF), now I have 4 total.
I want to have both IR remotes operate receiver #1.
I tried pairing the second remote with the receiver, but it would only allow me to switch from one to the other, I could never get them both to work at the same time.
Can anyone tell me how to get this to work, with step-by-step instructions for the not-so-smart?
Read your instruction book on setting the remote address. If you are using address 5 for TV 1 both remotes need to be set to address #5.
Issue with new 612 install
DVR 625 Forcing Anamorphic
