2 receivers | SatelliteGuys.US
2 receivers
BEATLE
25
FL
hi ...is it possible using 2 receivers off of one dish with just 1 lnb and splitting the signal between the two?...thanks
only IF both receivers are using the same polarity. Otherwise you need a dual feed LNB,
Bob
Beatle what do you want to do? I have two receivers connected to one LNBF but here are limitations as to what you can do with them.
i just want to run a splitter to one in the next room ..one cable to one receiver and the other to the one in the next room....what would i need to do thaT ...JUST a regular splitter or somethin else...thanks
You don't need a splitter if you use the "loop out" connection on the first receiver, however you will only be able to tune channels with the same (horizontal or vertical) polarity on both receivers. Just run a cable (RG6) from the "loop out" connection on the first receiver to the "LNB in" on the second receiver.
Bob
30w
LNB V/H Voltage
