2 receivers one motorized dish question | SatelliteGuys.US
jayelem
1,305
Chicago suburbs.
What is the configuration of this type of set up ?
Can both receivers move the motor ?
What does adding 2nd receiver require ?
Will a splitter work ?
I am asking because my Grandma will enjoy some stuff with me, but when I'm scanning and just looking for stuff a 2nd receiver in my room will be nicer as to not inconvenience her.
I understand multiple receivers can only watch one bird at a time.
Any suggestions ? that don't require a second motorized dish ?
if you have a dual LNB, one line goes to the 2nd receiver and the other line goes to the motor then to the main receiver.
in the above, no. Only one receiver can control the motor
if you have a dual LNB, just a second line run
high frequency splitter (up to 2200 mhz) will work, but the second receiver would only get the same polarity as the main. A dual LNB will allow the 2nd receiver to get both polarites (same satellite) :)
which is better?
C-Band question
