2 Lnbf's at 4° spacing | SatelliteGuys.US
Othea
176
Hi FTA-ers !
I'm having a tough time getting top signal strength on my dual lnbf bracket when satellites are only 4° apart.
My two lnbf's (standard ASC 321) are just too big -- both are tightly pressed against each other, but I still need a few millimeters tweaking space. Signal strength on both satellites is fair-to-middlin', but if I had a little more interstice, it would be quite strong on both.
Can anyone suggest an Lnbf whose circumference at the reception end is a tad smaller than the average lnbf from WSI and DMS?
If you are talking just a few MM. then maybe you could file a flat on each LNB where they touch to give you just enough clearance, then there is the ASC321s LNBF instead of a regular shape this LNBF goes straight out instead of down, but I think the LNB is the same diameter : ( I will measure both O/Dia. in the morning and let you know!
Checked they are the exact same size : (
Motorola DSR4410, DSR4420
Fortec Ultra
