2 GEOSat C2 LNBF's and 4 receivers... how to? | SatelliteGuys.US
Mikhel
On Vacation
378
San Diego, California
Hi, i was wondering if it was possible to have 4 receivers connected to two prime focus antennae (8ft and 10ft) equiped with a C2 LNBF in each of them (the ones with double output for C-Band), so i can watch 2 satellites in 4 different receivers at the same time.
Cheers
Mike
Oh... NICE!! i tought it would only function for Ku, with the receivers sending voltage and all that, i guess i was being paranoid :p.
Thanks a lot!!
Cheers
Mike
That is how mine is setup
dual LNB from 99W C-band
dual LNB from 121W C-band
into a 4x4 switch to 3 receivers (one port is bad) ;)
I'll be using a Pansat 2500a, a Fortec Lifetime Ultra, a CaptiveWorks 700s and either a CW600s Premium or a Cooltec i got pretty cheap :p (if i can bring it to life via JTAG).
Cheers
Mike
Hehehehe maaaan this cheap receivers keep appearing more and more often!! I guess the guys with the patch and wooden leg are getting rid of everything :p.
I'll see if i can get a Zinwell 4x4 :D, and tomorrow... operation JTAG.
Thanks!
Mike
NICE!! it works flawlessly... a friend lend me his 4x4 and it worked, now i'll try and get mine :D, also i connected the output from the 4x4 to a 4x1 DiSEqC where i had 2 other sats and... still have an opening for another sat!!:
113ºW (C-Band) and 116.8ºW (C-Band) in 4x4
95ºW Ku-------> 4x1 DiSEqC <---------- 123ºW Ku
Any of the receivers i have (CW's, Pansat or Fortec :D)
[PIE]Thanks!!![/PIE]
Now off to find one for me... i guess the ones included on those old Directv dishes with two LNBs also work, i think maybe on of those dishes it's gonna be easier to find than a standalone 4x4 switch since i am in México.
Mike
Would a 3x4 switch work for each dual output LNBF? it seems i can get a couple of 3x4 relatively cheap instead of a single 4x4.
Cheers
Mike
WOOOOOOOOOW hahahahahaha i like it!!! if i get it this is so i could have 4 sats in 8 receivers using a single switch? sounds pretty cool if it is that way :D.
Thanks for bringing up that thread.
Cheers
Mike
No, a 4x8 has four inputs - two from each of two LNBs: the Vertical and the Horizontal polarities.
BUT, by following several 4x4's or 4x8's with 4x1 diseqc switches, you could have EIGHT LNBs.
See our Switches Simplified FAQ... somewhere in the FAQ department... :rolleyes:
DMX741U FROM WS
Skyvision for programming
