2/11/2017 14:54 - Uplink Report - 22 Changes | SatelliteGuys.US
Uplink PC
Uplink Report PC
707
6
SatelliteGuys.US DishNetwork Uplink Report - 2/11/2017 14:54 - 22 Changes
Uplink Comparison Range: 2/11/2017 14:48 - 2/11/2017 14:54 (PST)
Name Changed:
5170(12) - LOCAL [MPEG4 HD] Echostar16 61.5W TP 19 Spotbeam 67 renamed to KTXS (Mkt: Abilene,TX (TX - ABC))(A)(H)
5170(12) - LOCAL [MPEG4 HD] Echostar16 61.5W TP 24 Spotbeam 05 renamed to WCTI (Mkt: Greenville,NC (NC - ABC))(A)(H)
5250(7) - LOCAL [MPEG4 HD] Ciel-2 129W TP 05 Spotbeam 16 renamed to KRCR (Mkt: Chico,CA (CA - ABC))(A)(H)
5252(6) - LOCAL [MPEG4 HD] Ciel-2 129W TP 05 Spotbeam 12 renamed to KTVM (Mkt: Butte,MT (MT - NBC))(A)(H)
5252(5) - LOCAL [MPEG4 HD] Ciel-2 129W TP 11 Spotbeam 31 renamed to WCYB (Mkt: Tri Cities,TN-NC-VA (VA - NBC))(A)(H)
5270(38) - LOCAL [MPEG4 HD] EchoStar14 119W TP 03 Spotbeam B10 renamed to KTXE (Mkt: San Angelo,TX (TX - ABC))(A)(H)
5272(13) - LOCAL [MPEG4 HD] Ciel-2 129W TP 06 Spotbeam 11 renamed to KECI (Mkt: Missoula,MT (MT - NBC))(A)(H)
6630(23) - LOCAL [MPEG2 SD] EchoStar14 119W TP 03 Spotbeam B2 renamed to KAEF (Mkt: Eureka,CA (CA - ABC))(A)(H)
6635(33) - LOCAL [MPEG2 SD] EchoStar14 119W TP 03 Spotbeam B2 renamed to KECA2 (KECA2)(Mkt: Eureka,CA)(A)(H)
7122(13) - LOCAL [MPEG2 SD] EchoStar10 110W TP 31 Spotbeam 37 renamed to KECI (Mkt: Missoula,MT (MT-NBC))(A)(H)
7617(5) - LOCAL [MPEG2 SD] EchoStar10 110W TP 18 Spotbeam 06 renamed to WCYB (Mkt: Tri Cities,TN-NC-VA (VA-NBC))(A)(H)
7619(28) - LOCAL [MPEG2 SD] EchoStar10 110W TP 18 Spotbeam 06 renamed to WCYBD (Mkt: Tri Cities,TN-NC-VA (VA-CW))(A)(H)
7731(12) - LOCAL [MPEG2 SD] EchoStar10 110W TP 27 Spotbeam 02 renamed to WCTI (Mkt: Greenville,NC (NC-ABC))(A)(H)
7736(48) - LOCAL [MPEG4 SD] Echostar16 61.5W TP 32 Spotbeam 05 renamed to GCTI (Mkt: Greenville,NC (NC-IND))(NA)(H)
7736(48) - LOCAL [MPEG2 SD] EchoStar10 110W TP 27 Spotbeam 02 renamed to GCTI (Mkt: Greenville,NC (NC-IND))(NA)(H)
7991(38) - LOCAL [MPEG2 SD] Ciel-2 129W TP 03 Spotbeam 47 renamed to KTXE (Mkt: San Angelo,TX (TX-ABC))(A)(H)
8171(12) - LOCAL [MPEG2 SD] Ciel-2 129W TP 03 Spotbeam 47 renamed to KTXS (Mkt: Abilene,TX (TX-ABC))(A)(H)
8179(40) - LOCAL [MPEG4 SD] Echostar16 61.5W TP 19 Spotbeam 67 renamed to QTXS (Mkt: Abilene,TX (TX-IND))(A)(H)
8179(40) - LOCAL [MPEG2 SD] Ciel-2 129W TP 03 Spotbeam 47 renamed to QTXS (Mkt: Abilene,TX (TX-IND))(A)(H)
9080(7) - LOCAL [MPEG2 SD] EchoStar10 110W TP 26 Spotbeam 43 renamed to KRCR (Mkt: Chico,CA (CA-ABC))(A)(H)
9085(21) - LOCAL [MPEG2 SD] EchoStar10 110W TP 20 Spotbeam 43 renamed to KRVU (Mkt: Chico,CA (CA-MN))(A)(H)
9089(6) - LOCAL [MPEG2 SD] EchoStar10 110W TP 29 Spotbeam 37 renamed to KTVM (Mkt: Butte,MT (MT-NBC))(A)(H)
Channels in the system: 9640
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
(FP) = Free Preview
The Format and Layout of the SatelliteGuys Uplink Report is © Copyright 2016 SatelliteGuys.US and may not be republished without written permission from SatelliteGuys.US.
SatelliteGuys Uplink PC Version 1.0.2
© 2016 - All Rights Reserved - SatelliteGuys Incorporated
2/11/2017 07:38 - Uplink Report - 102 Changes
someone needs to kick the uplink machine again
