2/04/2016 20:13 - Uplink Report - 30 Changes | SatelliteGuys.US
Uplink PC
Uplink Report PC
707
6
SatelliteGuys.US DishNetwork Uplink Report - 2/04/2016 20:13 - 30 Changes
Uplink Comparison Range: 1/31/2016 17:30 - 2/04/2016 20:13 (PST)
Channel Additions:
5207(24) - WFFP [MPEG4 HD] added to Ciel-2 129W TP 05 Spotbeam 39 (WFFP)(Mkt: Roanoke,VA)(NA)(H)
9288(24) - WFFP [MPEG2 SD] added to EchoStar10 110W TP 25 Spotbeam 05 (WFFP)(Mkt: Roanoke,VA)(NA)(H)
Channel Removals:
668 - MBCW [MPEG2 SD] (A)(H) removed from Anik F3 118.7W TP 03 ConUS (MBCW)
9887 - INFO [MPEG2 SD] (A)(H) removed from Anik F3 118.7W TP 26 ConUS (Dish Network Information Channel)
MAP Changed:
5250(19) - WKPT [MPEG4 HD] Ciel-2 129W TP 11 Spotbeam 31 map changed to (20) (Mkt: Tri Cities,TN-NC-VA (TN-ABC))(A)(H)
7615(19) - WKPT [MPEG2 SD] EchoStar10 110W TP 18 Spotbeam 06 map changed to (20) (Mkt: Tri Cities,TN-NC-VA (TN-ABC))(A)(H)
9560 - ESPND [MPEG4 HD] Nimiq5 72.7W TP 24 ConUS changed to Available , map (854) added (ESPN Deportes)(A)(H)
9560 - ESPND [MPEG4 HD] EchoStar11 110W TP 15 ConUS changed to Available , map (854) added (ESPN Deportes)(A)(H)
Tier Changed:
5249(19) - WJHL2 [MPEG4 HD] Ciel-2 129W TP 11 Spotbeam 31 changed to Available (Mkt: Tri Cities,TN-NC-VA)(A)(H)
5255(24) - KNDB [MPEG4 HD] Ciel-2 129W TP 12 Spotbeam 7 changed to Available (KNDB)(Mkt: Minot,ND)(A)(H)
7614(19) - WJHL2 [MPEG2 SD] EchoStar10 110W TP 18 Spotbeam 06 changed to Available (WJHL2)(Mkt: Tri Cities,TN-NC-VA)(A)(H)
9418(388) - PIXL [MPEG4 HD] Nimiq5 72.7W TP 24 ConUS changed to Free Preview (PIXL)(A)(FP)
9418(388) - PIXL [MPEG4 HD] EchoStar11 110W TP 22 ConUS changed to Free Preview (PIXL)(A)(FP)
9442(400) - TENIS [MPEG4 HD] Nimiq5 72.7W TP 30 ConUS changed to Subscription from Free Preview (The Tennis Channel)(A)
9442(400) - TENIS [MPEG4 HD] Ciel-2 129W TP 32 ConUS changed to Subscription from Free Preview (The Tennis Channel)(A)
9490(193) - SCI [MPEG4 HD] Nimiq5 72.7W TP 20 ConUS changed to Free Preview (Science Channel)(A)(FP)
9490(193) - SCI [MPEG4 HD] Ciel-2 129W TP 19 ConUS changed to Free Preview (Science Channel)(A)(FP)
9526(192) - ID [MPEG4 HD] Nimiq5 72.7W TP 06 ConUS changed to Subscription from Free Preview (Investigation Discovery)(A)(H)
9526(192) - ID [MPEG4 HD] Ciel-2 129W TP 32 ConUS changed to Subscription from Free Preview (Investigation Discovery)(A)(H)
9527(111) - DIY [MPEG4 HD] Nimiq5 72.7W TP 20 ConUS changed to Subscription from Free Preview (Do It Yourself Network)(A)(H)
9527(111) - DIY [MPEG4 HD] EchoStar11 110W TP 22 ConUS changed to Subscription from Free Preview (Do It Yourself Network)(A)(H)
Channel Moves:
5437(437) - FOXSE [MPEG4 HD] Echostar16 61.5W TP 05 Conus moved to Nimiq5 72.7W TP 08 ConUS (FOXSE)(A)(H)
5437(437) - FOXSE [MPEG4 HD] Ciel-2 129W TP 26 ConUS moved to Ciel-2 129W TP 25 ConUS (FOXSE)(A)(H)
Name Changed:
4269(369) - PLDIA [MPEG4 HD] Nimiq5 72.7W TP 24 ConUS renamed to MTVL (MTVL)(A)(H)
4269(369) - PLDIA [MPEG4 HD] Ciel-2 129W TP 19 ConUS renamed to MTVL (MTVL)(A)(H)
4684 - PLDIA [MPEG4 HD] Nimiq5 72.7W TP 24 ConUS renamed to MTVL (MTVL)(A)(H)
4684 - PLDIA [MPEG4 HD] Ciel-2 129W TP 19 ConUS renamed to MTVL (MTVL)(A)(H)
4950(369) - PLDIA [MPEG4 HD] EchoStar14 119W TP 01 Spotbeam B22 renamed to MTVL (MTVL)(A)(H)
9469(369) - PLDIA [MPEG4 HD] Nimiq5 72.7W TP 24 ConUS renamed to MTVL (MTVL)(A)
9469(369) - PLDIA [MPEG4 HD] Ciel-2 129W TP 19 ConUS renamed to MTVL (MTVL)(A)
Transponder Changes:
Echostar16 61.5W TP 09 Conus (21.500 8PSK 2/3) added.
Nimiq5 72.7W TP 05 ConUS (21.500 8PSK 2/3) added.
EchoStar10 110W TP 25 Spotbeam 05 (20.000 QPSK 5/6) added.
Ciel-2 129W TP 05 Spotbeam 39 (21.500 8PSK 2/3) added.
Anik F3 118.7W TP 03 ConUS (20.000 QPSK 3/4) removed.
Anik F3 118.7W TP 26 ConUS (20.000 QPSK 3/4) removed.
Channels in the system: 9778
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
(FP) = Free Preview
The Format and Layout of the SatelliteGuys Uplink Report is © Copyright 2014 SatelliteGuys.US and may not be republished without written permission from SatelliteGuys.US.
SatelliteGuys Uplink PC Version 1.0.1
© 2014 - All Rights Reserved - SatelliteGuys Incorporated
This is due to the ABC being moved to a sub of the CBS. So the "new" WKPT is My Network and on channel 20. ABC is still on 19 as noted
1/20/2016 12:43 - Uplink Report - 25 Changes
2/05/2016 12:53 - Uplink Report - 3 Changes
