15 pin output adapter? | SatelliteGuys.US
deathopie
44
I currently use the 15 pin rgb output of my 6000 receiver, the only other hd input on my tv is the component video input which currently has my prog scan dvd plugged into it. Does anyone have any ideas on how to use both of these inputs once I upgrade to a new reciever that does not have the rgb output? I was thinking a cheap rca a/b switch from radio shack would be the cheapest way to go if I share the component input, but there must be an easier way.
Are you upgrading to a 811 or a 921? The 921 has a DVI-I connector, which should be able to switch over to 15pin VGA/RGB with a simple cheap adapter.
The 811 uses DVI-D which has no such analog capability, so you would need to find a Component to RGB converter.
Discrete Codes?
Alternative to the Superdish?
