15 Minute shows not recording properly | SatelliteGuys.US
PreciousRoy
3
Has anyone else noticed that an 15 minute show that is set to record via the PVR doesn't record properly. For example, search for Aqua Teen Hunger Force. It appears on Cartoon Network. The show that appears on the top of the hour, when selected, sets the timer for the next show. It will not PVR the first show, only the second.
Hey Roy... I've noticed that too. It's kind of annoying, but considering that the PVR records using the names, it shouldn't be happening!
In any case, I've found that I record Family Guy (comes on before the 2 ATHF episodes), then edit the timer to end 30 minutes late. That way it records an hour and gets all 3 shows! If you just want to watch the ATHF, you could record the second one and set it to start 15 mins early...
Is there anything E* can do to fix this, or is it even a high priority?
Hard Drive Manufacturers getting in the mix
VCR to 811 Hookup
