I bought a 12foot Paraclipse and im wondering since its an old classic type mesh if its compatible with Ku Band "Its just like Hermitmans 12footer
If it's like mine, you'll have no problem picking up Ku signals. I use to have it set up to receive Ku and the signals came in strong and clear. Have fun.
I had a Paraclipse 12' dish that I bought back in the late 70's. Around 1988 I retrofitted it for KU and Horizon to Horizon mount. I still had the original (large hole) mesh on it from when it was new in the 70's. It worked good on KU, and C-Band and with FTA receivers. But as SatelliteAV mentioned you need to use something other than the button hook mount for the LNB. I converted mine to a tripod mount. It took me a few tries at getting it mounted correctly, but once I did, it worked great.
Would You Mind Taking Some Pictures Of It please. kind of give me an idea of what it looks like?
Yeah should be, Skyvision has replcement panels for some dishes I think...
does it matter if the mesh over lap the other mesh ? as long as the holes are covered up
The main thing is to keep the consistancy of the mesh flow, of the repaired area, as close to the mesh was before it was damaged. This is so it will reflect correctly to the LNB.
Limited time offer
