12/7/2011 6:01pm - Uplink Activity Report - 46 changes | SatelliteGuys.US
D
DigiDish Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 12/7/2011 6:01pm - 46 changes
Uplink Comparison Range: 12/07/2011 05:46P - 12/07/2011 06:01P
Channel Additions:
589 - ANTPR [MPEG2 SD] added to Echostar15 61.5W TP 21 ConUS beam (A)
597 - TVBSL [MPEG2 SD] added to EchoStar15 61.5W TP 14 ConUS beam (A) (H)
598 - RBTI [MPEG2 SD] added to Echostar15 61.5W TP 21 ConUS beam (RBTI (Brasilero)) (A) (H)
609 - SPRTV [MPEG2 SD] added to EchoStar15 61.5W TP 14 ConUS beam (A) (H)
737 - KINOE [MPEG2 SD] added to Echostar15 61.5W TP 21 ConUS beam (A) (H)
767 - RELIG [MPEG2 SD] added to Echostar15 61.5W TP 21 ConUS beam (A) (H)
817 - SIC [MPEG2 SD] added to EchoStar15 61.5W TP 29 ConUS beam (A) (H)
6822 - UP5 [MPEG4 HD] added to EchoStar15 61.5W TP 27 ConUS beam (Virtual Channel) (NA)
Channel Removals:
6830 - ANTPR (A) (H) [MPEG2 SD] removed from Echostar15 61.5W TP 21 ConUS beam
6831 - TVBSL (A) (H) [MPEG2 SD] removed from EchoStar15 61.5W TP 14 ConUS beam
6832 - RBTI (A) (H) [MPEG2 SD] removed from Echostar15 61.5W TP 21 ConUS beam (RBTI (Brasilero))
6833 - SPRTV (A) (H) [MPEG2 SD] removed from EchoStar15 61.5W TP 14 ConUS beam
6834 - RELIG (A) (H) [MPEG2 SD] removed from Echostar15 61.5W TP 21 ConUS beam
6835 - SIC (A) (H) [MPEG2 SD] removed from EchoStar15 61.5W TP 29 ConUS beam
6836 - KINOE (A) (H) [MPEG2 SD] removed from Echostar15 61.5W TP 21 ConUS beam
Channel Moves:
8873 - WJAN [MPEG4 SD] moved from EchoStar15 61.5W TP 26 ConUS beam to EchoStar8 77W TP 13 ConUS beam (Mkt:West Palm Beach, FL-Miami, FL-IND) (A) (H)
5280 - WGXAD [MPEG4 HD] moved from EchoStar15 61.5W TP 27 ConUS beam to EchoStar8 77W TP 13 ConUS beam (Mkt:Macon, GA-Macon, GA-N/A) (A) (H)
5281 - WMAZ [MPEG4 HD] moved from EchoStar15 61.5W TP 27 ConUS beam to EchoStar8 77W TP 13 ConUS beam (Mkt:Macon, GA-Macon, GA-CBS) (A) (H)
5282 - WMGT [MPEG4 HD] moved from EchoStar15 61.5W TP 27 ConUS beam to EchoStar8 77W TP 13 ConUS beam (Mkt:Macon, GA-Macon, GA-NBC) (A) (H)
5283 - WGXA [MPEG4 HD] moved from EchoStar15 61.5W TP 27 ConUS beam to EchoStar8 77W TP 13 ConUS beam (Mkt:Macon, GA-Macon, GA-FOX) (A) (H)
5284 - WMUM [MPEG4 HD] moved from EchoStar15 61.5W TP 27 ConUS beam to EchoStar8 77W TP 13 ConUS beam (Mkt:Macon, GA-Cochran, GA-PBS) (A) (H)
7881 - WGNM [MPEG4 SD] moved from EchoStar15 61.5W TP 27 ConUS beam to EchoStar8 77W TP 13 ConUS beam (Mkt:Macon, GA-Macon, GA-IND) (A) (H)
7883 - WPGA [MPEG4 SD] moved from EchoStar15 61.5W TP 27 ConUS beam to EchoStar8 77W TP 13 ConUS beam (Mkt:Macon, GA-Perry, GA-ABC) (A) (H)
5280 - KAQY [MPEG4 HD] moved from EchoStar15 61.5W TP 22 ConUS beam to EchoStar8 77W TP 01 ConUS beam (Mkt:Monroe, LA-Columbia, LA-ABC) (A) (H)
5281 - KNOE [MPEG4 HD] moved from EchoStar15 61.5W TP 22 ConUS beam to EchoStar8 77W TP 01 ConUS beam (Mkt:Monroe, LA-Monroe, LA-CBS) (A) (H)
5282 - KTVE [MPEG4 HD] moved from EchoStar15 61.5W TP 22 ConUS beam to EchoStar8 77W TP 01 ConUS beam (Mkt:Monroe, LA-El Dorado, AR-NBC) (A) (H)
5283 - KARD [MPEG4 HD] moved from EchoStar15 61.5W TP 22 ConUS beam to EchoStar8 77W TP 01 ConUS beam (Mkt:Monroe, LA-West Monroe, LA-FOX) (A) (H)
5284 - KLTM [MPEG4 HD] moved from EchoStar15 61.5W TP 22 ConUS beam to EchoStar8 77W TP 01 ConUS beam (Mkt:Monroe, LA-Monroe, LA-PBS) (A) (H)
5285 - KETZ [MPEG4 HD] moved from EchoStar15 61.5W TP 22 ConUS beam to EchoStar8 77W TP 01 ConUS beam (Mkt:Monroe, LA-El Dorado, AR-PBS) (A) (H)
7815 - KMCT [MPEG4 SD] moved from EchoStar15 61.5W TP 22 ConUS beam to EchoStar8 77W TP 01 ConUS beam (Mkt:Monroe, LA-West Monroe, LA-IND) (A) (H)
5200 - WCHS [MPEG4 HD] moved from EchoStar15 61.5W TP 26 ConUS beam to EchoStar8 77W TP 08 ConUS beam (Mkt:Charleston, WV-Charleston, WV-ABC) (A) (H)
5201 - WOWK [MPEG4 HD] moved from EchoStar15 61.5W TP 26 ConUS beam to EchoStar8 77W TP 08 ConUS beam (Mkt:Charleston, WV-Huntington, WV-CBS) (A) (H)
5202 - WSAZ [MPEG4 HD] moved from EchoStar15 61.5W TP 26 ConUS beam to EchoStar8 77W TP 08 ConUS beam (Mkt:Charleston, WV-Huntington, WV-NBC) (A) (H)
5203 - WVAH [MPEG4 HD] moved from EchoStar15 61.5W TP 26 ConUS beam to EchoStar8 77W TP 08 ConUS beam (Mkt:Charleston, WV-Charleston, WV-FOX) (A) (H)
7319 - WQCW [MPEG4 SD] moved from EchoStar15 61.5W TP 26 ConUS beam to EchoStar8 77W TP 08 ConUS beam (Mkt:Charleston, WV-Portsmouth, OH-CW) (A) (H)
7321 - WPBY [MPEG4 SD] moved from EchoStar15 61.5W TP 26 ConUS beam to EchoStar8 77W TP 08 ConUS beam (Mkt:Charleston, WV-Huntington, WV-PBS) (A) (H)
7322 - WOUB [MPEG4 SD] moved from EchoStar15 61.5W TP 26 ConUS beam to EchoStar8 77W TP 08 ConUS beam (Mkt:Charleston, WV-Athens, OH-PBS) (A) (H)
7325 - WPBO [MPEG4 SD] moved from EchoStar15 61.5W TP 26 ConUS beam to EchoStar8 77W TP 08 ConUS beam (Mkt:Charleston, WV-Portsmouth, OH-PBS) (A) (H)
471 - SPORT [MPEG2 SD] moved from EchoStar15 61.5W TP 29 ConUS beam to EchoStar15 61.5W TP 08 ConUS beam (Pay Per View Sports & Events) (A)
605 - ANTEN [MPEG2 SD] moved from EchoStar15 61.5W TP 29 ConUS beam to EchoStar15 61.5W TP 08 ConUS beam (Antenna Satellite (Greek)) (A)
640 - TVJPN [MPEG2 SD] moved from EchoStar15 61.5W TP 29 ConUS beam to EchoStar15 61.5W TP 08 ConUS beam (TV Japan SAP) (A)
814 - GLOBO [MPEG2 SD] moved from EchoStar15 61.5W TP 29 ConUS beam to EchoStar15 61.5W TP 08 ConUS beam (TV Globo Internacional) (A) (H)
911 - ANTRA [MPEG AUDIO] moved from EchoStar15 61.5W TP 29 ConUS beam to EchoStar15 61.5W TP 08 ConUS beam (ANT1 97.2 FM) (A) (H)
9620 - BTV [MPEG2 SD] moved from EchoStar15 61.5W TP 29 ConUS beam to EchoStar15 61.5W TP 08 ConUS beam (Business TV) (A)
Transponder Changes:
EchoStar15 61.5W TP 22 ConUS beam 21500 8PSK 2/3 removed
EchoStar15 61.5W TP 26 ConUS beam 21500 8PSK 2/3 removed
Channels in the system: 8373
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
(FP) = Free Preview
The Format and Layout of the SatelliteGuys Uplink Report is © Copyright 2011 SatelliteGuys.US and may not be republished without written permission from SatelliteGuys.US.
The SatelliteGuys Uplink Report is powered by Digiblur Technologies! - DigiDish v11.10.31
© 2011 - All Rights Reserved - SatelliteGuys Incorporated
or wanted to put the scares out there about the final solution for international instead. I bet ala carte Globo ($20) and TV JPN ($25) will become like RAI at 119 and remain at 61.5 even if they go MPEG4 8PSK.
Arabic (April - August 2011) done
Hindi (July - November 2011) done
Greek (September 2011 - February 2012) in process
Japanese (November - December 2011) not gonna happen, has not even moved to 68xx yet
Polish (January - March 2012) in process
Portuguese (January SPRT, SICNO, BENFC] - March [SIC, RTP] 2012)
Brazilian (January [RBTI, TVBI] - March [RCORD,GLOBO] 2012)
Even with the new 48 hr rewind paying $20 for a single channel and then having to pay for higher speed access just isn't going to entice subs to jump from satellite to IP delivery so good luck dish if a sub cant see 119/118.75.
DishWorldIPTV
Thanks Dish! Now I know why my timers on my local HD channels last night! Heck the timer was removed completely!
Sorry for replying to old thread, but are the international channels going mpeg4, the reason I ask is they either Dish/SPTV have beeen using the HD feed for SPRT sd and it's always been letterbox and it's worse when they blackbars on the side. If they were to convert to Mpeg4 could they convert the feed to 16x9 sd?
D
1/4/2012 5:01am - Uplink Activity Report - 6 changes
D
1/4/2012 2:46pm - Uplink Activity Report - 48 changes
