Could someone please clarify exactly which format DISH supports for the 1080p VOD. Please use hz and fps precisely. Is it 1080p 25 fps 60hz? Thanks! Go Adrian Peterson and the VIKES!
E* actually did something right for once.... It's all about keeping the original framerate. Films (and some Tv shows) are shot with movie cameras at 24 frames per second. The latest fad is to have a Tv that can accept a signal at 24fps and display it at a multiple of that 48/72/120Hz so that there is no conversion to 60Hz. It's the conversion that creates an occasional stutter in the picture on 60Hz fixed pixel displays (lcd/dlp/plasma)....So now my question is why is this the format supported...
Progressive video at rate of 24 fps (actually 23.98 fps) for 60 Hz. This is a standard & it is what E* uses.
for 60hz?![]()
Yes for 60hz. That is the electrical system that the US uses. You need a link?
It applies if you shooting it. Not so much on playback.24p has nothing to do with 60hz though.
If you're referring to the power source of the camera, OK, but that's irrelevant and unrelated to the frame rate of what is being filmed. It's like saying everyone in the US has a 60hz TV.
I'm referring to shooting HD Video. Which shoots 24fps @ 60 hz or in 50 hz areas shoots at 25fps. Here's a sentence pulled from the info about HDV to relate to the statement.
HDV camcorders, capable of 1080p video, record progressive video at rates of 24 fps (actually 23.98 fps) and 30 fps (actually 29.97 fps) for 60 Hz markets, and at 25 fps rate for 50 Hz markets.
Well Excuse Me for noting the fact that it is shot differently here at 60Hz than it is in 50Hz markets. Really when it comes to being shot there is more of it shot on HDV than film now. So it seems related to the frequency at which it is encoded to Video. No, as far as anyone that has 60 Hz only equipment Unless it is a multiple of 24 on refresh rate then it is not going to work. Most of the sets that display 24fps are using what is know as 2:3 pulldown to do the job. Some better than others & some pretty badly.
Isn't it illegall to get/watch Dish in another country? Why should they do anything for them?...And what does Dish do for 1080p VOD for them?
Limited time offer
