1080i vs 720p | SatelliteGuys.US
1080i vs 720p
ocaddict
298
Atlanta
Ok, I don't really wanna start this age old argument again. However, would like to know what you guys prefer to run your 921's at and why? Just curious.
If it's like the 811 I'd think you'd want to run it in the program you're watching's output
I'm with Puss 'n Boots, match the output to the program format. Unless your display's converter is absolutely atrocious.
If you read what it says on the resolution selection screen. It's like this
480P - Check this if your TV is only capable of displaying 480P
720P - Check this if your TV is only capable of displaying 720P
1080i - Check this if your TV is capable of displaying 1080i
So that makes it sound as if your TV CAN run 1080i, then you should. Anywho, who do you know what resolution channels are outputing?
Picture quality continues to go downhill !
Dish CSR Refused My Upgrade!
