103W Ku NC mux | SatelliteGuys.US
103W Ku NC mux
Chewie
352
199
California
Hello All
Just wondering if this Mux still active.
Let me know.
Thanks in Advance.
Regards.
Chewie
I change the LNB to a Universal LNB and is not getting it, I was getting them with the MK -1 lnb.
I might have to go back to it.
The MK-1 is a standard LNBF and uses a LO of 10750 the universal LNBF uses a different dual LO of 9750-10600. You need to change the LNB settings in the receiver menu when you change the LNB type. Since the Universal LNB has a built in 22khz switch the 22khz setting will be auto or greyed out in the LNB menu when you set the LO to 9750-10600.
Reactions: raydio
FTA Receiver
Galaxy 28 ku band
