10/30/2010 2:57am - Uplink Activity Report - 28 changes | SatelliteGuys.US
  • Thread starter Thread starter DigiDish Uplink Report
  • Start date Start date
  • Replies Replies 0
  • Views Views 2K
D
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 10/30/2010 2:57am - 28 changes
Uplink Comparison Range: 10/30/2010 02:47A - 10/30/2010 02:56A
Channel Removals:
5820 - SKDL (NA) [MPEG2 SD] removed from EchoStar11 110W TP 16 ConUS beam (Source channel for sports packages)
5820 - SKDL (NA) [MPEG4 SD] removed from Nimiq5 72.7W TP 01 ConUS beam (Source channel for sports packages)
5821 - SKDL (NA) [MPEG2 SD] removed from EchoStar14 119W TP 21 ConUS beam (Source channel for sports packages)
5821 - SKDL (NA) [MPEG4 SD] removed from Nimiq5 72.7W TP 01 ConUS beam (Source channel for sports packages)
5822 - SKDL (NA) [MPEG2 SD] removed from EchoStar14 119W TP 12 ConUS beam (Source channel for sports packages)
5822 - SKDL (NA) [MPEG4 SD] removed from Nimiq5 72.7W TP 19 ConUS beam (Source channel for sports packages)
5823 - SKDL (NA) [MPEG2 SD] removed from EchoStar14 119W TP 21 ConUS beam (Source channel for sports packages)
5823 - SKDL (NA) [MPEG4 SD] removed from Nimiq5 72.7W TP 01 ConUS beam (Source channel for sports packages)
5824 - SKDL (NA) [MPEG2 SD] removed from EchoStar14 119W TP 18 ConUS beam (Source channel for sports packages)
5824 - SKDL (NA) [MPEG4 SD] removed from Nimiq5 72.7W TP 19 ConUS beam (Source channel for sports packages)
5825 - SKDL (NA) [MPEG2 SD] removed from EchoStar14 119W TP 16 ConUS beam (Source channel for sports packages)
5825 - SKDL (NA) [MPEG4 SD] removed from Nimiq5 72.7W TP 19 ConUS beam (Source channel for sports packages)
5826 - SKDL (NA) [MPEG2 SD] removed from EchoStar14 119W TP 12 ConUS beam (Source channel for sports packages)
5826 - SKDL (NA) [MPEG4 SD] removed from Nimiq5 72.7W TP 19 ConUS beam (Source channel for sports packages)
Channel Moves:
411 - PRIME [MPEG2 SD] moved from EchoStar14 119W TP 06 ConUS beam to EchoStar11 110W TP 16 ConUS beam (Fox Sports Net Prime Ticket) (A) (H)
411 - PRIME [MPEG4 SD] moved from Nimiq5 72.7W TP 22 ConUS beam to Nimiq5 72.7W TP 01 ConUS beam (Fox Sports Net Prime Ticket) (A) (H)
415 - FOXAZ [MPEG2 SD] moved from EchoStar14 119W TP 08 ConUS beam to EchoStar14 119W TP 21 ConUS beam (Fox Sports Arizona) (A) (H)
415 - FOXAZ [MPEG4 SD] moved from Nimiq5 72.7W TP 22 ConUS beam to Nimiq5 72.7W TP 01 ConUS beam (Fox Sports Arizona) (A) (H)
416 - FOXSW [MPEG2 SD] moved from EchoStar14 119W TP 09 ConUS beam to EchoStar14 119W TP 12 ConUS beam (Fox Sports Southwest) (A) (H)
416 - FOXSW [MPEG4 SD] moved from Nimiq5 72.7W TP 22 ConUS beam to Nimiq5 72.7W TP 19 ConUS beam (Fox Sports Southwest) (A) (H)
417 - FOXW [MPEG2 SD] moved from EchoStar14 119W TP 10 ConUS beam to EchoStar14 119W TP 21 ConUS beam (Fox Sports West) (A) (H)
417 - FOXW [MPEG4 SD] moved from Nimiq5 72.7W TP 22 ConUS beam to Nimiq5 72.7W TP 01 ConUS beam (Fox Sports West) (A) (H)
418 - FOXMW [MPEG2 SD] moved from EchoStar14 119W TP 12 ConUS beam to EchoStar14 119W TP 18 ConUS beam (Fox Sports Midwest) (A) (H)
418 - FOXMW [MPEG4 SD] moved from Nimiq5 72.7W TP 22 ConUS beam to Nimiq5 72.7W TP 19 ConUS beam (Fox Sports Midwest) (A) (H)
420 - FOXS [MPEG2 SD] moved from EchoStar14 119W TP 13 ConUS beam to EchoStar14 119W TP 16 ConUS beam (Fox Sports South) (A) (H)
420 - FOXS [MPEG4 SD] moved from Nimiq5 72.7W TP 22 ConUS beam to Nimiq5 72.7W TP 19 ConUS beam (Fox Sports South) (A) (H)
422 - SUN [MPEG2 SD] moved from EchoStar14 119W TP 16 ConUS beam to EchoStar14 119W TP 12 ConUS beam (Sun Sports) (A) (H)
422 - SUN [MPEG4 SD] moved from Nimiq5 72.7W TP 22 ConUS beam to Nimiq5 72.7W TP 19 ConUS beam (Sun Sports) (A) (H)
Channels in the system: 7710
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
(FP) = Free Preview
The Format and Layout of the SatelliteGuys Uplink Report is © Copyright 2010 SatelliteGuys.US and may not be republished without written permission from SatelliteGuys.US.
The SatelliteGuys Uplink Report is powered by Digiblur Technologies! - DigiDish v10.10.28
© 2010 - All Rights Reserved - SatelliteGuys Incorporated
D
10/29/2010 6:17pm - Uplink Activity Report - 36 changes
D
11/1/2010 12:38pm - Uplink Activity Report - 6 changes
