1 Remote with 2 DirecTV Receivers | SatelliteGuys.US
mdntblu
213
Corona, CA
I did some installation at a house which had 2 DirecTV receivers (1 HD DVR, and 1 HD non-DVR). Both receivers are in the same cabinet. Is there a way to program 1 remote to control both receivers? Also are these receivers capable of using the RF remote? If I got 1 RF remote can I control both of them from the 1 RF remote just by switching a switch?
Your question isn't clear do you want 1 remote code to control both receivers at the same time?
No I want to be able to control 2 receivers with one remote but not at the same time. Like can I switch the switch at the top to a different thing to control the other receiver and leave it on DTV to control the first receiver? I would like to use the RF remote if that's possible.
Yes you can. One unit is controlled with the standard setting and the other with the remote set to AV1. The instructions should be in the receiver manual. If you can't find it there, do a search here. I remember seeing it at one point.
MLB Extra Innings FREE Preview 7/16 - 7/22
Sorry for Switch to Direct TV
