1/30/2011 10:39am - Uplink Activity Report - 27 changes | SatelliteGuys.US
  • Thread starter Thread starter DigiDish Uplink Report
  • Start date Start date
  • Replies Replies 0
  • Views Views 2K
D
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 1/30/2011 10:39am - 27 changes
Uplink Comparison Range: 01/30/2011 10:28A - 01/30/2011 10:38A
Channel Additions:
6802 - UP2 [MPEG2 SD] added to EchoStar8 77W TP 13 ConUS beam (Virtual Channel) (NA)
Channel Removals:
6812 - UP4 (NA) [MPEG2 SD] removed from EchoStar8 77W TP 13 ConUS beam (Virtual Channel)
Channel Moves:
5280 - WGXAD [MPEG4 HD] moved from EchoStar8 77W TP 16 ConUS beam to EchoStar8 77W TP 13 ConUS beam (Mkt:Macon, GA-Macon, GA-N/A) (NA)
5281 - WMAZ [MPEG4 HD] moved from EchoStar8 77W TP 16 ConUS beam to EchoStar8 77W TP 13 ConUS beam (Mkt:Macon, GA-Macon, GA-CBS) (A) (H)
5282 - WMGT [MPEG4 HD] moved from EchoStar8 77W TP 16 ConUS beam to EchoStar8 77W TP 13 ConUS beam (Mkt:Macon, GA-Macon, GA-NBC) (A) (H)
5283 - WGXA [MPEG4 HD] moved from EchoStar8 77W TP 16 ConUS beam to EchoStar8 77W TP 13 ConUS beam (Mkt:Macon, GA-Macon, GA-FOX) (NA)
5284 - WMUM [MPEG4 HD] moved from EchoStar8 77W TP 16 ConUS beam to EchoStar8 77W TP 13 ConUS beam (Mkt:Macon, GA-Cochran, GA-PBS) (A) (H)
7881 - WGNM [MPEG4 SD] moved from EchoStar8 77W TP 16 ConUS beam to EchoStar8 77W TP 13 ConUS beam (Mkt:Macon, GA-Macon, GA-IND) (A) (H)
7883 - WPGA [MPEG4 SD] moved from EchoStar8 77W TP 16 ConUS beam to EchoStar8 77W TP 13 ConUS beam (Mkt:Macon, GA-Perry, GA-ABC) (A) (H)
5280 - KBMT [MPEG4 HD] moved from EchoStar8 77W TP 10 ConUS beam to EchoStar8 77W TP 09 ConUS beam (Mkt:Lake Charles, LA-Beaumont, TX-ABC) (A) (H)
5281 - KFDM [MPEG4 HD] moved from EchoStar8 77W TP 10 ConUS beam to EchoStar8 77W TP 09 ConUS beam (Mkt:Lake Charles, LA-Beaumont, TX-CBS) (A) (H)
5282 - KPLC [MPEG4 HD] moved from EchoStar8 77W TP 10 ConUS beam to EchoStar8 77W TP 09 ConUS beam (Mkt:Lake Charles, LA-Lake Charles, LA-NBC) (A) (H)
5283 - KVHP [MPEG4 HD] moved from EchoStar8 77W TP 10 ConUS beam to EchoStar8 77W TP 09 ConUS beam (Mkt:Lake Charles, LA-Lake Charles, LA-FOX) (NA)
5285 - KLTL [MPEG4 HD] moved from EchoStar8 77W TP 10 ConUS beam to EchoStar8 77W TP 09 ConUS beam (Mkt:Lake Charles, LA-Lake Charles, LA-PBS) (A) (H)
5280 - KAQY [MPEG4 HD] moved from EchoStar8 77W TP 14 ConUS beam to EchoStar8 77W TP 01 ConUS beam (Mkt:Monroe, LA-Columbia, LA-ABC) (A) (H)
5281 - KNOE [MPEG4 HD] moved from EchoStar8 77W TP 14 ConUS beam to EchoStar8 77W TP 01 ConUS beam (Mkt:Monroe, LA-Monroe, LA-CBS) (A) (H)
5282 - KTVE [MPEG4 HD] moved from EchoStar8 77W TP 14 ConUS beam to EchoStar8 77W TP 01 ConUS beam (Mkt:Monroe, LA-El Dorado, AR-NBC) (A) (H)
5283 - KARD [MPEG4 HD] moved from EchoStar8 77W TP 14 ConUS beam to EchoStar8 77W TP 01 ConUS beam (Mkt:Monroe, LA-West Monroe, LA-FOX) (A) (H)
5284 - KLTM [MPEG4 HD] moved from EchoStar8 77W TP 14 ConUS beam to EchoStar8 77W TP 01 ConUS beam (Mkt:Monroe, LA-Monroe, LA-PBS) (A) (H)
5285 - KETZ [MPEG4 HD] moved from EchoStar8 77W TP 14 ConUS beam to EchoStar8 77W TP 01 ConUS beam (Mkt:Monroe, LA-El Dorado, AR-PBS) (A) (H)
7815 - KMCT [MPEG4 SD] moved from EchoStar8 77W TP 14 ConUS beam to EchoStar8 77W TP 01 ConUS beam (Mkt:Monroe, LA-West Monroe, LA-IND) (A) (H)
6809 - UP4 [SD TV] moved from EchoStar8 77W TP 09 ConUS beam to EchoStar8 77W TP 10 ConUS beam (Virtual Channel) (NA)
6822 - UP5 [MPEG4 HD] moved from EchoStar8 77W TP 01 ConUS beam to EchoStar8 77W TP 14 ConUS beam (Virtual Channel) (NA)
14240 - KVHP2 [EPG] moved from EchoStar8 77W TP 10 ConUS beam to EchoStar8 77W TP 09 ConUS beam (OTA EPG:Lake Charles, LA)(NA)
14843 - KLTL2 [EPG] moved from EchoStar8 77W TP 10 ConUS beam to EchoStar8 77W TP 09 ConUS beam (OTA EPG:Lake Charles, LA)(NA)
15200 - KLTL3 [EPG] moved from EchoStar8 77W TP 10 ConUS beam to EchoStar8 77W TP 09 ConUS beam (OTA EPG:Lake Charles, LA)(NA)
Transponder Changes:
EchoStar8 77W TP 16 ConUS beam 22500 QPSK TURBO CODED 5/6 removed
Channels in the system: 7468
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
(FP) = Free Preview
The Format and Layout of the SatelliteGuys Uplink Report is © Copyright 2011 SatelliteGuys.US and may not be republished without written permission from SatelliteGuys.US.
The SatelliteGuys Uplink Report is powered by Digiblur Technologies! - DigiDish v10.10.28
© 2011 - All Rights Reserved - SatelliteGuys Incorporated
D
1/30/2011 9:14am - Uplink Activity Report - 68 changes
D
1/30/2011 11:04am - Uplink Activity Report - 2 changes
