1.2 meter cband | SatelliteGuys.US
1.2 meter cband
jasjas
84
28
Palatine il 60074 w of chicago
HI
I have a 1.2 meter channel master dish i got from a radio station that moved.
it was a 2 way dish.
i would like to try to recieve 101 c band sat and would like to know if a c band lnbf can be mounted to it, it is off set and takes a 40 mm lnb.
is there any lnbf i can mount to this as most look like the neck is too large.
since the new ones have better gain and lower noise i thought i would give it a shot.
i have a coolsat 5000 and a pansat 9000 for the recievers.
1 have used this for ku and worked great, but seems a waist for the size.
The only channel on 101 C-Band that I know of is Golden Eagles Broadcasting
That transponder is very strong so a 1.2m should be fine.
edit: found the signal screen shot when I locked on GEB with a 1.2m dish
Many C Band lnbf are 65 mm throat Dia.
Some folks here claim good C Band performance with the flat Scalar that comes with LNBF.
Some like the WS Conical Scalar which comes with a black plastic adapter for mounting a C Lnbf to Offset dish.
Check out one of our sponsers at top of page for this equipment.
Some folks say that depending on your dishes f/d one or the other Scalar will be better.
Enjoy
PS- If you motorize this and side mount a Ku lnbf you will get better performance then with a C/Ku LNBF.
Here are some links for the above:
- the C2 dual output C-band LNBF is on sale right now
- the conical scalar and LNBf mounting bracket is available
- another site shows performance boost with conical
- if you insist on trying a flat scalar, read this
Iceberg and knowmiddlename signal reports on 1.2m dishes:
http://www.satelliteguys.us/free-air-fta-discussion/188490-minibud-1-2m.html
HI
They did make a C band feed for a offset dish got one somewhere i was looking to see if i can find someone in Barbados for some reason they use them there so i can sell it
LOL i got a ton of satellite stuff i need to unload
what tp is strong in SatMex 5 @ 116.8 W
Intelsat 805 at 55.5°W
