I was amazed how small Underworld Evolution was... Guys if you like or dislike a drive you can post a review of it here http://www.satelliteguys.us/reviews//showcat.php?cat=27 We will set up same type sub catagory for DirecTV users...
I called twice this morning and both reps said to call back at 8:00am Eastern as they could not activate until then. About 7:30 I called again and this time they got me going. I came back this afternoon and decided to archive several HD movies including King Kong, Star Wars, Harry Potter and Pirates of the Caribbean. The screen showed I had 239 gb of storage available and my transfer would take 53 gigs. First, the screen noted a time required for download of 3 hours and some odd minutes but a moment later it switched to 2 hours 47 minutes. It has been 20 minutes into the process now and I just went to check the status bar. It says it is sending my selections to the hard drive but there is no green status bar showing nor is there any time remaining. I know the transfer is not complete but it looks like you have to wait until the hard drive itself stops blinking to know the downloads have in fact taken place. Perhaps too much content thrown at it at once messes up the status indicators. I hope so because we really have to know how much time is left and the status of the download. I'm just going to keep going until I see my WD stop blinking and then see what is on it.
I saw the same issue with the status bar disappearing after you check a few times. It won't come back during this transfer but you will get the popup that says it's done.
Been running about thirty minutes now, warm but not uncomfortable to the touch. Actually, maybe slightly cooler than the 622 right next to it. Unit is sitting in an open area of the shelf, lots of air circulation, and there is an a/c vent about 18" above it. So, even if it hits 100 again here in SoCal, should be nice and comfy up there.
Thats good to know but not good enough. I think we need a status bar that works throughout the entire duration of the download.
This is what has been going on for months with my PocketDish. The difference is that when I plugged in my PD the download would freeze the screen. If the download was half way done and there was 1 hour and 20 minutes (for example) left showing on the status bar, that is where it stayed and you could not operate any part of the 622 receiver at all. There would be nothing left to do but a soft reboot. Sometimes the download would take and sometimes not.
Someone posted that the PD issue as been resolved and I am anxious to check mine; however, we can not have a status bar that either sticks in one place or shows nothing at all, as is the case now with the external hard drive. They'll have to work this out.
Sean, I am in the middle of a transfer right now and when checking the progress from live tv I also get the blank time and status bar.
Limited time offer
