Just got my tracking number from Robert.
Yippie!
Since Robert is about 45 minutes from here and its going FedEx Ground, it will probably be here tommorow.![]()
Thats cool Scott. Hey let us know how it works.
Yippie!
Ok guys, I'm an idiot when it comes to this hd-dvd stuff.
I heard that you needed an hdmi for the toshiba hdvd player but with xbox360 it works with component? The reason I'm asking is my lcd is a few years old and only have component.
I got my Xbox HD DVD player today and watched Nacho Libre on it and wow it was amazing. The picture looks as good as the HD-a1 that I have and the load time was just as good as my regular dvd player. What a great buy!
For now, you should be able to play HD-DVDs at up to 1080p resolution over component video on the XBOX 360.
AACS is designed to limit the resolution of HD-DVDs to 960x540 pixels over the component outputs by setting a flag in the player called the Image Constraint Token. Essentially, this reduces the HD-DVD to the same resolution as a standard DVD.
When the studio begins using ICT, M$ will need to begin selling a HDMI or DVI cable.
If your LCD TV has DVI, you can get an HDMI - DVI cable, both standards support HDCP.
Does the regular DVD player on the 360 handle DTS?
Very well explained Kevin ... but a few clarifications:
1080p is only supported via VGA connection. As I understand, the component connection will only support up to 1080i.
AACS/ICT will require reduced resolutions over any output that does not support HDCP. The clarification I want to make here is that it affects the VGA connection as well, not just component.
I have been trying to contact Microsoft on this issue. I am trying to find out if digital output is even possible with the current hardware. It would have to support HDCP, and my guess is that the Xbox hardware does not contain that particular bit of silicon.
Yes both HDMI and DVI cables support HDCP-transmitted data, but that does not necessarily mean his LCD can decrypt an HDCP signal. Remember, you need HDCP support on both ends of the signal or it's not going to work.
- Shane Sturgeon
My TV does 1080p Westinhhouse W42L2, when I set the 360 to 1080p my tv info shows 1920x540 @ 60mhz is that right.
Limited time offer
