Scott Greczkowski not sure if this has been asked yet. Will everything function OK if both Hopper 3 HDMI cable and Hopper Plus HDMI cable attached to TV by two different TV HDMI inputs? And without having to disconnect anything or rebooting?
I think I created some confusion with the way my post was written. I did not mean to imply the features mentioned were lost from a Wally. I was referring to what you lose compared to just a straight up Hopper 3 without the Hopper +. The PIP functionality is disabled with the Hopper + along with Alexa integration which the Wally does have. There may be other features, but I am only going by my research on the Hopper 3 prior to signing up and not actual experience with the Hopper 3 without the Hopper +. Sorry for the confusion.
The button for PIP is still there, but if you click it you get a message stating the feature is not active.
Thanks for clarifying. I get that same message any time I click the PIP button on the remote for my Wally. Maybe when Dish figures out how to add PIP to the Hopper+, they will also finally get around to activating PIP on Wally.I was expecting the PIP feature and was surprised by this because I did not see anything stating it had been disabled with the Hopper + integration.
The Alexa setup button is non-existent.
I also wanted the Alexa integration. :-(
I also loved the convenience of the Alexa integration when I first got my Wally. It is especially convenient since you can tell Alexa exactly how far forward or backward to skip, without needing multiple button presses like you would need with a remote control.I would miss the Alexa integration. I use Alexa to control my Hopper3 when I am on my treadmill. That way I don't need to be messing with a remote while watching TV while working out. I can tell it to skip ahead avoiding commercials just telling Alexa what to do. This works well since I have Alexa throughout my home. I realize that Google also would work but I only have Google in one room.
I think this was answered here:Scott Greczkowski not sure if this has been asked yet. Will everything function OK if both Hopper 3 HDMI cable and Hopper Plus HDMI cable attached to TV by two different TV HDMI inputs? And without having to disconnect anything or rebooting?
If the Hopper detects that both HDMI's are connected, it will tell you to use the Hopper+ HDMI connection. That is why I suggested the HDMI switch, and having both (Hopper 3 and Hopper+) connected to the same input on the TV. My guess is that the switch would disrupt the Hopper 3 HDMI connection to the TV (while using the Hopper+) so this message would be disabled. Then, flipping the switch the other way would disrupt the Hopper+ HDMI connection to the TV, allowing the Hopper 3 to only detect the Hopper 3 HDMI connection. However, nobody has replied whether my proposed solution actually works. (Note that whenever the HDMI switch is flipped, the Hopper+ USB connection to the Hopper 3 would also need to be established / disconnected, depending on which way you are flipping the HDMI switch.)2 - WHen you plug the HDMI into the Hopper while the plus us connected, you get a page telling you that the HDMI is disable and to connect to the Plus
I have a 2X4 HDMI switch in my system now. Might have to get a 4x4 switch. Will wait and see.I think this was answered here:
Have you tried downloading an Alexa App from the store?I agree. The tech thought the PIP/multi view feature would be added back In the future. The button for PIP is still there, but if you click it you get a message stating the feature is not active. The Alexa setup button is non-existent. I was expecting the PIP feature and was surprised by this because I did not see anything stating it had been disabled with the Hopper + integration. I also wanted the Alexa integration. :-(
No, the plus disables the Hopper 3 HDMI outputScott Greczkowski not sure if this has been asked yet. Will everything function OK if both Hopper 3 HDMI cable and Hopper Plus HDMI cable attached to TV by two different TV HDMI inputs? And without having to disconnect anything or rebooting?
Thanks HipKat. So have you tried disconnecting the H+ and connecting the HDMI cable back into the Hopper? If so, does Hopper require a reboot or do you have to download a different software?No, the plus disables the Hopper 3 HDMI output
My total wild assed guess is it might be a bandwidth issue with transferring (in the example of 6 channels of multiview) or a HD PIP picture so it could switch between any of those, over USB 2.Multi view and PIP are some of the best features of the Hopper 3. Why would they disable it with the Hopper +? Does dish realize how much back lash they will get even from new customers. It doesn't state on dish.com that you will lose those 2 features when you place a new order. Thanks
With him, it's pet, feed and get dragged! LOLDo your duty. Pet feed walk.
Not yet. I may try that but would that allow my Alexa devices to control the Hopper? That is what I want.Have you tried downloading an Alexa App from the store?
What I've heard is that it takes 20 minutes fort the Hopper to go back to just being a Hopper and yeah, it needs a rebootThanks HipKat. So have you tried disconnecting the H+ and connecting the HDMI cable back into the Hopper? If so, does Hopper require a reboot or do you have to download a different software?
I'm not sure. The Hopper is connected to the same Network as your Alexa's so it may. I'd be interested to find outNot yet. I may try that but would that allow my Alexa devices to control the Hopper? That is what I want.
...as we all saw in this picture:...in the Hopper + software as the + is just basically a big Roku...
I don't think it requires a software download each time you switch back-and-forth. I was looking for the post where Scott explained it, and I think I found it:Thanks HipKat. So have you tried disconnecting the H+ and connecting the HDMI cable back into the Hopper? If so, does Hopper require a reboot or do you have to download a different software?
So, with the base DISH software, normal Hopper operation is supported. Then, when an Android device (Hopper+ and/or new Joey 4) is connected, the Hopper uses that Android software. Both software versions are stored on the Hopper, so there is no need for a new download when switching. At least, that is my understanding. I am sure Scott will clarify more about this, as soon as that information can be released.The android boxes get a base DISH software, that starts with a P, however there is other software that is downloaded via Android, so there are many times your android devices will get software updates however the DISH software version may not change.
I will show this off more when I can.![]()
The HDMI from the Hopper 3 goes into the Hopper Plus. The HDMI from the Hopper plus goes into the TV where the Hopper 3 was plugged in.Scott Greczkowski not sure if this has been asked yet. Will everything function OK if both Hopper 3 HDMI cable and Hopper Plus HDMI cable attached to TV by two different TV HDMI inputs? And without having to disconnect anything or rebooting?
This is correct.What I've heard is that it takes 20 minutes fort the Hopper to go back to just being a Hopper and yeah, it needs a reboot
The Alexa controlled my Hopper 3 fine, however it does not seem to work with the Hopper Plus hooked up.Not yet. I may try that but would that allow my Alexa devices to control the Hopper? That is what I want.
Can the Joey 4s be set up with no Hopper+? I don't need the Joey apps to be opperational.This is correct.
And it will reboot itself a few times going back to Hopper 3 mode. Again the Joey 4's will continue to work fine without the Hopper Plus hooked up.![]()
Limited time offer
