How do you know this? There is nothing on the internet that says that it is not working.Dish lost sat 77, anyone knows about this ?
Here we are now!There's going to be a major influx of expats on the forum wondering where there SD feeds are...
I posted this back on June 23.....Seems the Option B was the real option.....My guess for these changes (the order has nothing to do with priority):
A.- Need more space for Dish Mexico service (Medcom Group 51% & Dish 49%).
B.- Dishnetwork agreement with Quetszat 1 ends by November 2021 (of course they could extend year by year as needed or until the Satellite expires).
C.- S.B. Capability (posted by nelson 61 in other thread "Echostar 23 is being relocated to 110°W as spare") Echostar 23 has the following configuration: Its communications payload consists of 32 Ku-Band transponders as well Ka- and S-Band payloads. Can't find that it's Spot Beam capable.
If this is true, they need to prepare for the expiration date of Echostar X (49 Spot Beam Capable) that might be due by 2/25/2022. They actually have even or close SB capability in east (EXVI & EXVIII@61.5°W) & west (EIV@ 119°W & EX@110°W) arc; After EX end of life they will have less SB capability in West arc. What I need to fit here is the reason of freeing CONUS TP's......
The only surprise for me was the reason, no one here had an answer for the reason of the migration, I was guessing, and one of my guesses was the leasing contract with Quetzsat was due on November 2021, now the puzzle is complete (at least for me), I could say that Dish doesn't have the cash flow to use 40% of orbital slot 77°W not even with 49% shares with Mexican Group (Medcom) that is currently using the other 60% of the satellite probably Dish Mexico is next in line unless the move was for more bandwidth for the Dish Mexico service; could be that Dish is on diet, and watching the calories (expenses) indication that times are changing.This wasn't a big surprise if I remember correctly this was supposed to happen a few months ago.
Ok, the Test Installation routine straightened out the chart labeling, leaving red checks where 77 used to be. I wonder if a future update will eliminate the check for the third EA slot...Hmmm, I expected 77 to be gone from my diagnostics page, but there's no label for 61.5 either. The tuner check marks are there, and the "Satellite 61.5 locked" is there, just no label on the check box chart. I'll try a Test Installation in a little while to see if that fixes it. Nothing serious, just curious...
Doubt it, since the Conn. and red X message specifically means that a LNB is detected, but no valid sat signal is present. The firmware on the LNB would have to be modified to permanently disable that specific LNB and I doubt they would even bother. Plus, and I'm guessing you used a 1000.4 EA LNBF, it belongs to port one on the switch, so it's alot harder for a receiver itself to hide it being empty compared to port 3/4 like some portable dishes do when you are only getting 2 sats.Ok, the Test Installation routine straightened out the chart labeling, leaving red checks where 77 used to be. I wonder if a future update will eliminate the check for the third EA slot...
Limited time offer
