Scott, what are you using for the ota antenna?
A pair of RCA non power rabbit ears.
This is in my office way up here in the sky.
Ah, I thought you were using the new ATSC 3.0 tuner at your house. The ss must be pretty good in the office.A pair of RCA non power rabbit ears.
Are you using an LTE filter?Signal strength went from 93% to 99% when they flipped WCCT from 1.0 to 3.0
Actually we don't get that much up here. (but again I am using standard rabbit ears) I put my HDHR online at TV stations received at Hartford, CT-SatelliteGuys-4K tuner1
Same here. Used to be rock solid for me.....Channel 61 is spotty at my house and I'm thinking it may be due to LTE interference.
And I'm about 13.5 miles from the towers. You are probably less than 10.Same here. Used to be rock solid for me.....
Don't forget to give us an update on how it works.I just ordered a CM LTE/5G filter to see if that will resolve the RF36 (WFSB) issue. No antenna issues. I was told back in 2019 that I may need a filter for my location.
Thanks Scott that's what I was wondering. Thought maybe they were doing work on them this weekend or something. So with my Sony X80J TV with the 3.0 tuner when I first scanned at about 5:30pm yesterday they came up as 3.1 1080p enhanced audio, 8.1, 20.1 and 61.1 then the signal dropped out but I still get them all in atsc 1.0 minus wfsb (which always breaks up this far west) but the 3.0 signal was holding well for a half hour. I read that some folks near Htfd were having 61 drop out so I didn't know if that was 3.0 and an indication that the 3.0 broadcasts were having issues.Still coming in here in Hartford.
rabbitears.info
Sort by Virtual Channel as all the ATSC 3.0 channels show up with a 1 before then. (So for but example channel 61 is 161)
are you referring to HD homerun or in a TV?Still coming in here in Hartford.
rabbitears.info
Sort by Virtual Channel as all the ATSC 3.0 channels show up with a 1 before then. (So for example channel 61 is 161)
But the channel numbering seems different for me. In my guide it lists 3.0 range as in the same uhf range I believe, highest number of 80 or so. I may contact Sony next week. I'd love to hear if others west of Hartford are receiving the 3.0 channels ok
Limited time offer
