Really? You sure spend a lot of time degrading them and like the Everready battery they just keep on hop, hop, hopping along. That's gotta get your goat!I never said it didn't.
I just don't like Kangaroos.
Just curious, why didnt you use just one 4:2 switch and channel stack splitters? Instead of the four 4:4 switches.Or what I did with 15 wallys the other day..View attachment 140438View attachment 140439
How about Wallabies? Do you like Wallabies?I never said it didn't.
You know someone with Channel stack splitters?Just curious, why didnt you use just one 4:2 switch and channel stack splitters? Instead of the four 4:4 switches.
When you have a chance, can you share a link on what channel splitters are, how to install them, etc?We've got 'em.![]()
OK, tkz.Just Google 'Dish channel stack splitters' and that will tell you more than I can here.
Basically they allow up to 8 Wally's on each port of a DPH42 or on a hybrid LNB.
I just found Claude's new avatar:I never said it didn't.
Wouldn't putting it before the splitters push power through the splitters?Yes,we do. if you don't have channel stack splitters, you can use normal splitters as long as you put the power inserter between the splitter and the switch so no power passes through the splitters.
OK, tkz.
LOL, yep. That is my old red neck headend board when I had four HWSs and one Joey. Looks pretty busy.Hey Charles, when I Googled 'DISH channels stack splitters' about half way down the page it looks like your setup.
No because the power goes towards the switch, not the receivers.Wouldn't putting it before the splitters push power through the splitters?
The Holland ones that IHS techs carry are pretty much the same frequency. 5-2150 MHz and 4-2150 MHz'Normal splitters' don't generally have the frequency range necessary.
Limited time offer
