The repack is coming up soon, but the addition of ATSC 3.0 may (or may not) be happening concurrently with the repack so you may need to stay on your toes going forward.And VHF lo isn't and won't be in my market after the repack.
Soldering is great, but remember that these elements make for really great heat sinks.I think I'll just solder it back together.
60/40 doesn't, but there are solders (and the attendant fluxes) that are made specifically for aluminum soldering.Solder doesn't stick to aluminum.
That's what you get for thinking.Well I don't think foil,will last long outside.
That's what you get for thinking.![]()
I had some time yesterday so I tested it out. I wasn't able to pick up Global or CHCH but I guess that's to be expected because they are in the red zone. What is the point of the lower boom on the VU120? Is it just for support?![]()
For the extra support/strength.Bigger antenna so there's more wind load and it is "split" in the middle so it helps with that and a second clamp on the mast.What is the point of the lower boom on the VU120?
Limited time offer
