If a satellite receiver or meter supports WLAN or Bluetooth streaming, an Android app can used for dish aiming.
Can't think of a setup like that right now. I can use my slingbox and slingplayer app to view the satellite receiver but the latency sucks. Nothing is going to ID the sat unless it's a high dollar meter.Can I use an Android app that does the same thing as a TV when pointing your dish??shows the signal and sat id and all that..
All depends on the phone and the calibration of the phone. I have had good luck, but always making sure to calibrate each time.Trust Me, Ive tried. They're all garbage. There good for elevation, but not for azimuth.
Have heard that the cheap dollar store smart phones, you are correct they never work. If it is a decent phone and you are having issues make sure to calibrate it each time.
Did you calibrate your sensor before trying? This must be done or your readings will be way off.I'm using a iPhone SE, so it's not the phone.
I'd highly recommend a 36" (90cm) dish. I have 4 LNBF's on mine for 103/99/95/91W. It gets me NBC in 4 time zones, their news feeds (NC1-NC12), RT, NHK, JBS, Infowars (not really news), CCTV/CGTN, and ABC NewsOne 1-4.
I get 87W good on a fixed 76 cm with a Avenger pll lnbf on it here in Ct. As Fta4pa said though, there's no margin for error. It's a touchy sat to get, you have to be spot on.
95W is strong and easy to lock on a 76 cm dish. CCTV news is on there in English if you don't mind foreign news channels. For a few years I had a small direct TV dish setup for 95W Ku and it worked fine but I get it on one of my c band dishes now, so I took it down to make room for other better dishes.
I have another 76 cm fixed dish set on 103W too for NHK and that comes in good all the time, but the NBC feeds there don't always come in, the dish is a bit small for those.
Me too. Also, NBC West Came back on. Just Color Barskeep in mind that those NBC feeds are not always on. it's perfectly normal that at times, one or several of them show a blank screen.
On 95W, Macroview still scans in but I get a blank screen...
Yeah, that is not a 24hr NBC west feed like you would get from OTA or pay TV.Me too. Also, NBC West Came back on. Just Color Bars
This bird is too easy for me to tune in!![]()
It must be because I'm using an undersized reflector.
Limited time offer
